Results 1 to 8 of 8
    Jul 2017
    binaklas ko po yung cv joint (inner) may lumabas na oil parang putik na, puede bang gear oil ang replacement. thanks
    cv grease. inquire sa tgc auto parts...
    Quote Originally Posted by eagleye21 View Post
    Use synthetic grease not oil. Na-rerepack yan malamang. Dapat tanggalin lahat ng lumang grease tapos lagyan bago.
    Yung wuerth na brand or Top 1 okay siya. Basta lithium based para matibay at long-lasting.
    CV joint grease uses a lithium and molybdenum sulphide compound mixed in.
    Sent from my P01MA using Tapatalk
    Feb 2009
    Outboard birfield joint grease and inboard plunge joint grease are sometimes of different formulation. But both are NLGI 1 viscosity (semi fluid). To avoid surprises, ascertain whether the grease is the correct or recommended type. If the grease is thicker, it can cause noise and the car consumes more fuel.
    Jan 2008
    Hindi po putik yan.. cv joint grease yan na mala uhog..
    Yan po ang tama na grease para dyan. Hindi po pwede yung grease na ginagamit pag repack ng bearing
    Feb 2014
    well lithium is just a thickener. and i'm not even sure if CV joint grease uses a lithium thickener. but yes "moly" or molybdenum disulphide is an important component in a CV joint grease.
    a CV joint probably won't last very long if you just use a plain grease like the 2 pictures above
    My mistake. It should contain moly indeed.
    Wuerth has a specific cv joint grease pala.
    Never had problems with top 1 but it is for cv of 4wd so its not used that often that is why it may have been okay after all this years. Different from passenger cars cv joints.
cv joint oil use?
