Results 1 to 7 of 7
- Sep 2013
- 2
September 19th, 2013 04:57 PM #1mga sir bakit ganun, pag sa mga abrupt braking di cya totally nagfull stop, may abante pa ng konti ano kaya problema?
September 19th, 2013 05:03 PM #2
Does your ride have ABS? If yes normal yan kasi ganun naman talaga dapat hindi basta nag lock ang brakes para makapag steer ka pa ng maayos...
Ang i double check mo na lang is the distance bago ka mag full stop with different speeds para malaman specific distances (I suggest you do this in a track and not on a public road though)
Lastly, it doesn't hurt to have your braking system checked kasi ibang usapan yan kapag yung abrupt braking mo ay galing sa mabagal na takboLast edited by jodski; September 19th, 2013 at 05:08 PM. Reason: Added more details
September 19th, 2013 05:17 PM #3
Even the most expensive car hindi humihinto kaagad pag nagbbreak. On the otherhand kung inaabot pa ng more than 10 meters at hindi pa din totally break yun auto, baka ubos na mga pads nyan. Have it checked to avoid accident.
- Nov 2008
- 641
September 19th, 2013 05:33 PM #4What model, make, and year of your car? When was the last time you serviced your brake system? Do you need to pump your brake during braking? As mentioned above, though the braking distance is not that long, it is normal with cars with ABS.
- 53,883
September 21st, 2013 09:43 AM #6brake pads. worn out or contaminated.
brakeline air. try bleeding them.
inherent in the design. learn to live with it. my old escort was like that..
September 23rd, 2013 04:07 PM #7
when the brakes are applied to stop the car, it does not respond to zero velocity immediately since there is momentum. the moving vehicle kinetic mechanical energy is converted to heat energy by the brakes. it takes time for the brakes to convert this motion to heat, consequently, the hot brakes components do not immediately quench to ambient temperature. imagine stopping like the way you meant it, like hitting a brick wall from X mph to decelerate immediately to zero mph, you will sustain a lot of injury and sustain damage to your car. it is a matter of inertia and momentum we learned from high school
Tesla Philippines
