Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Feb 2009
    Quote Originally Posted by ronron77 View Post
    Mga sirs patulong naman po. ano po kaya problema nito? Pag kunwari nag menor na at padating na sa isang traffic light, nararamdaman ko yung pag sway ng sasakyan. Yung para bang may nagtutulak sa both sides at inaalog alog siya.
    Nangyayari lng ito pag mga 10 to 20 kph. Sa high speed naman, walang sway pero may naririnig akong umuugong (low frequency) sa ilalim na parang mahinang ikot ng propeller.
    Alignment issue ba ito or drive shaft problem kaya? Pinacheck ko na sa mekaniko pero hindi nya mahanap problema. Okey pa naman gulong hindi uneven ang wear nya at 80% pa ang tread nya since 1 year pa lang napapalitan. Yung sterring wheel hindi rin naka centro o nakaparallel kapag nakaparallel na yung gulong.
    Tapos everytime na nirerelease ko yung clutch for a downshift, may naririnig akong tunog na parang sirang bearing sa ilalim.
    Ride is hyundai tucson mt thanks po sa mga tutulong at magrereply sa mga tanong ko.
    have your subframe mount/insulators checked. they might have shifted the whole carriage that holds the engine/transmission and the steering and suspension assemblies out of alignment
    Jan 2009
    When decelerating and you're experiencing this swaying, were you stepping on the brakes as well, and getting ready to stop? If yes, it may be caused by DTV (often referred to colloquially as a 'warped' rotor). Check out the doc below to validate if it's indeed caused by DTV (Disk Thickness Variation).
    http://www.powerbrake.co.za/download..._01_judder.pdf
    Nakita ko na problema sirs. Nung paikot kong kinapa yung gulong sa left rear, naramdaman ko yung mga protruding wires sa may inner side wall ng gulong. Natusok pa kamay ko. Tatanggalin ko yon bukas para ma examine mabuti pero definitely, may tama na ang tread.
    Thanks a lot for helping me guys. The best po kayo at sana huwag kayo magsawa sa kakabigay ng advise.
    Time to change the tires.
    Sent from my Nexus 7 using Tapatalk 2
    Yes sir i decided to buy a new pair. Oblong na nga yung isang gulong. It was just a matter of time before i had a tire blowout. Now the ride is back to normal.
Car sways from left to right at low speed
