Results 1 to 10 of 15
- Mar 2009
- 14
October 6th, 2013 07:57 AM #1Mga sirs patulong naman po. ano po kaya problema nito? Pag kunwari nag menor na at padating na sa isang traffic light, nararamdaman ko yung pag sway ng sasakyan. Yung para bang may nagtutulak sa both sides at inaalog alog siya.
Nangyayari lng ito pag mga 10 to 20 kph. Sa high speed naman, walang sway pero may naririnig akong umuugong (low frequency) sa ilalim na parang mahinang ikot ng propeller.
Alignment issue ba ito or drive shaft problem kaya? Pinacheck ko na sa mekaniko pero hindi nya mahanap problema. Okey pa naman gulong hindi uneven ang wear nya at 80% pa ang tread nya since 1 year pa lang napapalitan. Yung sterring wheel hindi rin naka centro o nakaparallel kapag nakaparallel na yung gulong.
Tapos everytime na nirerelease ko yung clutch for a downshift, may naririnig akong tunog na parang sirang bearing sa ilalim.
Ride is hyundai tucson mt thanks po sa mga tutulong at magrereply sa mga tanong ko.
October 6th, 2013 10:27 AM #3
i suggest a complete check of the car's suspension system both front and rear. have the car lifted up, with a lift that is positioned on the chasis/body and not on the wheels, to allow the wheels to hang. that is the only way they will be able to find out if the suspension has broken parts. if there is weight on the wheels then they will not be able to see what is broken. di kaya makita yan problem mo ng mekaniko lang na nakahiga sa ilalim ng kotse kasi kung may basag na suspension/mount nakalapat din yun so hindi makikita. inaangat yan sa shop at pag walang weight sa wheels saka lang maghihiwalay yung basag na part.
and also, don't use the car until the problem is solve, you may just end up in a very bad accident if things suddenly just break. baka mandamay ka pa ng passengers mo or pedestrians kawawa naman.
October 6th, 2013 03:25 PM #4
Sounds like lumps on the tire treads. Run your hands on all tire treads and feel for lumps. If you find any, that tire is gone and should be replaced asap.
- Jul 2012
- 62
October 7th, 2013 11:03 AM #5Same Diagnosis for me. Tire lumps should be the killer! I've heard a lot of accidents caused by tire explosion because of tire lumps. Replace your tire and have your camber and wheel alignment checked
But yea, check your suspension as well
- Mar 2009
- 14
October 7th, 2013 12:28 PM #6sirs, salamat po sa replies.
Just to give you an update. I had the suspension checked. Na repack na po yung tie rod ends, wheel bearings, at ball joints. Na align na rin yung camber (manual, not computer). pinacheck ko na rin po yung tires at wala naman nakitang problema. Nung na i drive ko na, ganon pa rin at mas lalong nagswe sway at low to medium speed. Tapos yung brake light at battery light indicator sa dashboard umilaw na ng tuluyan. So hindi ko muna ginamit ang oto.
Binalik ko dun sa shop na nag ayos pero hindi naman na daw nila alam yung cause bastat na align naman nilang mabuti. Pinacheck ko na rin yung mga engine mounts etc pero ok naman sila. Baka nasa makina na yung problema o sa drive shaft.daw hindi ko naman alam kung ano ito.. ang sakit na ng ulo ko sa sobrang abala. Ano pa kaya ang dapat gawin? Maghahanap ako ng ibang talyer pag may time po ako.
Salamat.
October 7th, 2013 04:33 PM #7
I have that same uneasiness on our 2010 Tucson when the tyres are too soft.
Can you try a different set of tyres just to rule it out? The unit has never had an accident or bad pohole?
- Nov 2011
- 79
October 8th, 2013 08:37 AM #9
what about the shocks? medyo similar yung nangyari sa kotse ko kaya lang instead na sway eh bounce from front left corner to rear right corner ( i hope you get what i mean) the culprit.... busted right rear shock absorber, hth
- Mar 2009
- 14
October 8th, 2013 03:19 PM #10*Vinj : it never had an accident sir but there are occasional "pothole mishaps"
*chaitotek: yes sir..all tires have 33 psi
*box_type : eto ang hindi ko pa nacheck sir..will try to check this later
Thanks a lot!
