Results 1 to 10 of 25
- Oct 2013
- 2
October 19th, 2013 02:36 AM #1good day mga sir
any suggestions for best suspension specialist shop in fairview quezon city, im planning to replace my car's ball joints and shocks
thanks for your help guys
- Oct 2013
- 172
October 23rd, 2013 10:49 PM #2
October 23rd, 2013 11:01 PM #3
Wag ka lang paalign sa kanila. Repairs are good and hindi sila napapahiya sa gawa.
- Oct 2013
- 172
October 24th, 2013 09:24 AM #5
Cruven does repairs to the balljoints and shocks; i've tried this before and its still better to replace with a new set of shocks and balljoints (affordable naman KYB and 555 replacement brands).
You can consider buying the parts on your own from the auto supply or even from Banawe. If you go to Banawe try Wheelers Suspension Haus along N. Roxas.
Try also checking out Motech in Fairview. I go to their branch in Pampanga and they're okay for the usual maintenance work (may discount card pa).
- May 2012
- 372
- Oct 2015
- 1
October 27th, 2015 08:34 AM #7Dati OK sa Wheelers. Nagpapagawa ako dati dun. Kahapon nagbalik ako pa-check up ng sasakyan. Parang tinataboy ako nung technician na medyo bata pa na payat. Ang angas at bastos makipag-usap. Sa simula pa lang hiniritan na ako na pina-check up ko na raw dati yung dala kong sasakyan at parang asar, eh 1st time ko lang dinala yun. Tapos nung nag-da-diagnose bastos makipag-usap at parang galit na di mo
maintindihan. Halatang tinatamad na tumanggap ng trabaho. Nangtataboy na ang dating talaga. Tapos ang diagnosis sablay pa pala. Dinala ko sa Exalta/Full Gear (same owner) at Zafra afterwards. Sila pareho ng diagnosis pero sa Wheelers iba ang sinabi sa akin. Na-turn off ako bigla sa Wheelers tuloy. Sayang lang hinintay ko sa pila. Wala pang mag-aasikaso sa iyo dun pag dating mo tsaka walang nag-co-control ng pila, nagkakaunahan sa pila tuloy.
- Dec 2015
- 5
December 21st, 2015 10:55 AM #8May problem ako with my new vios 3rd gen rear suspension. i recently put a 17 inch mags and tires na 205x50. sumasayad sya sa likod pag may 3 passengers. how can we solve this?
- Aug 2013
- 475
December 22nd, 2015 09:00 AM #9
- Dec 2015
- 5
December 22nd, 2015 08:22 PM #10
