Results 1 to 10 of 24
- Aug 2013
- 4
September 3rd, 2013 11:11 AM #1Nagpa camber alignment po ako (mit adv) sa tyre pro banawe. 1320, toe, caster, camber...
Q) harap lang ba talaga included nun? harap lang kasi ginawa, sabi harap lang daw. hahah.. sori di ko alam...
btw, bina lance din ung harap (100 each)
Q2) kina camber ba likod?
Q3) and ung likod hindi na daw bina balance? hindi na daw sabi nung tech (although hindi nmn ako siningil sa likod syempre)
thanks.
- Jul 2010
- 165
September 3rd, 2013 11:21 AM #2Q1: Yup for Mit Advenventure harap lang ung kina-camber kasi ung likod has a rear axle.
Q2: No need na para sa likod i-camber again because the adventure has a rear axle.
Q3: Most tire shops suggest not to balance the tires at the back. But for me I prefer the tire to be balance as well.
- Aug 2013
- 4
September 3rd, 2013 11:38 AM #3hahah.. thanks.. kala ko na goyo ako lol... anyway, may warranty daw sila, balik dw ako free
alignment / caster - 10 days (balik daw once)
c wbep correction - 3 months (balik monthly)
- Aug 2013
- 4
September 3rd, 2013 12:03 PM #4ano nga pala ung c/ wbep correction? parang malabo ang hit sa google. ty
- Jul 2010
- 165
September 5th, 2013 10:55 AM #5baka yan ung camber sir. Minsan after 2 weeks or more after adjusting the camber pwede magbago ulit ung setting nung camber. So need mo lang ibalik sa shop for check-up.
September 5th, 2013 01:54 PM #7
- Jul 2010
- 165
September 5th, 2013 02:30 PM #8On the car manuals its advised to have your wheel camber and alignment checked every 20,000 kms
- Mar 2008
- 53,883
September 6th, 2013 10:44 AM #9you usually can not do camber adjustment on solid axles like the adventure's rear. the camber is set for life.. the life of the axle. which is usually longer than the life of the vehicle.
Tesla Philippines
