Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Mar 2013
    guys ask ko lng panu b increase ung rear height ng auto ko kc ang baba ng likod by the way toyota corolla 97 auto ko tnx tnx
    Jun 2010
    palagyan mo ng "sapatos" yan ang term ng mga gumagawa ng fabricated rubber bushing using pay loader tyres. mga 350 each, pa tangal mo muna saka mo dalhin sa bushingan, ganyan ginawa ko sa uneven stance ng civic ko sa rear.
    Oct 2009
    sasapian sa gawaan ng bushing swak na swak yan..
    Quote Originally Posted by dlinker View Post
    Have a "lifter" installed. It is a rubber donut that sits between the spring and shock to make it sit higher.
    Sir GH mga magkano yung ganun?
    Mar 2012
    Quote Originally Posted by d'flash View Post
    Nasa 750 yata pair tapos labor mga 400... yan pinalagay ko sa likod for the sayad/kayod issue.
    ^lifter yung tawag sakanya? or may iba pang tawag? and anong brand yung okay ipalagay?
    Feb 2009
    if you make the rear ride height higher, the caster angle turns less positive or negative making the vehicle wander from side to side. what you might consider doing is to restore to original ride height by replacing worn out bushing and tired rear coil springs. you do not try to correct a problem with another problem
    Mar 2012
    rubber lifter, generic ata yan, may sizes lang...
    if you make the rear ride height, the caster angle turns less positive or negative making the vehicle wander from side to side. what you might consider doing is to restore to original ride height by replacing worn out bushing and tired rear coil springs. you do not try to correct a problem with another problem
    Oo nga naman baka may tama na shocks mo kaya mababa na ride. pasilip mo muna.
    Last time I had it done was P500 each and another P400-P500 for install for each corner.
how to increase rear car height?
