Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Aug 2013
    Nagpa camber alignment po ako (mit adv) sa tyre pro banawe. 1320, toe, caster, camber...
    Q) harap lang ba talaga included nun? harap lang kasi ginawa, sabi harap lang daw. hahah.. sori di ko alam...
    btw, bina lance din ung harap (100 each)
    Q2) kina camber ba likod?
    Q3) and ung likod hindi na daw bina balance? hindi na daw sabi nung tech (although hindi nmn ako siningil sa likod syempre)
    thanks.
    Jul 2010
    Q1: Yup for Mit Advenventure harap lang ung kina-camber kasi ung likod has a rear axle.
    Q2: No need na para sa likod i-camber again because the adventure has a rear axle.
    Q3: Most tire shops suggest not to balance the tires at the back. But for me I prefer the tire to be balance as well.
    Aug 2013
    hahah.. thanks.. kala ko na goyo ako lol... anyway, may warranty daw sila, balik dw ako free
    alignment / caster - 10 days (balik daw once)
    c wbep correction - 3 months (balik monthly)
    Aug 2013
    ano nga pala ung c/ wbep correction? parang malabo ang hit sa google. ty
    Jul 2010
    baka yan ung camber sir. Minsan after 2 weeks or more after adjusting the camber pwede magbago ulit ung setting nung camber. So need mo lang ibalik sa shop for check-up.
    Aug 2010
    how do you know when car need camber alignment?
    Jul 2011
    Quote Originally Posted by trucker111 View Post
    kapag hindi pantay ung pudpod ng gulong.
    minsan pwede mo rin masilip, parang pike ung gulong.
    Jul 2010
    On the car manuals its advised to have your wheel camber and alignment checked every 20,000 kms
    you usually can not do camber adjustment on solid axles like the adventure's rear. the camber is set for life.. the life of the axle. which is usually longer than the life of the vehicle.
    Oct 2005
    Any recommended shop for camber and alignment?
Camber Alignment and Wheel Balancing Q
