Results 1 to 8 of 8
May 8th, 2006 12:05 PM #3
you will need to replace your brake pads and brake shoes...your suking shop might advise you to reface your brakes also...
Tsikot Member Rank 5
- Nov 2003
- 3,848
- Jun 2005
- 215
May 8th, 2006 11:07 PM #6
minsan pag while backing out sa parking namin me sound din pag nag break but once nag forward na ok na ala na sound
May 8th, 2006 11:12 PM #7
brake pads lang yan. almost all brake pads, whether for disk brakes or drum brakes, have a metal strip that is positioned at the same point as the minimum allowable pad thickness. when it comes to contact with the metal of the brake disk or drum it will make a squeeling sound. that serves as a warning to the driver that the brake pads are worn and needs replacement. replace it immediately since if you keep on using it there will be 2 consequences. 1, your brake disk or drum will get scratched by this metal strip. you will then need to reface the disk or drum, or worse, replace it also. 2nd, a worn brake pad can cause you an accident due to brake failure, and you surely don't want that to happen.
May 8th, 2006 11:22 PM #8
Originally Posted by cutedoc
Tesla Philippines
