Results 1 to 8 of 8
    Apr 2006
    help po...
    pag-nag-brake ako...may squeaking sounds...ano po ang sira?
    most likely....worn out or dirty brake pads.
    Oct 2005
    you will need to replace your brake pads and brake shoes...your suking shop might advise you to reface your brakes also...
    Nov 2003
    sandali lang check yan... either pads or rotors lang.
    Jun 2005
    Your brake pads in worn out, Its time to get it replace.
    minsan pag while backing out sa parking namin me sound din pag nag break but once nag forward na ok na ala na sound
    brake pads lang yan. almost all brake pads, whether for disk brakes or drum brakes, have a metal strip that is positioned at the same point as the minimum allowable pad thickness. when it comes to contact with the metal of the brake disk or drum it will make a squeeling sound. that serves as a warning to the driver that the brake pads are worn and needs replacement. replace it immediately since if you keep on using it there will be 2 consequences. 1, your brake disk or drum will get scratched by this metal strip. you will then need to reface the disk or drum, or worse, replace it also. 2nd, a worn brake pad can cause you an accident due to brake failure, and you surely don't want that to happen.
    Quote Originally Posted by cutedoc
    drum brake ba doc? yung mga drum brakes meron automatic adjustment yan (esp toyota vehicles) which automatically adjusts the brake shoes adjusting nut when backing up. maybe it has adjusted the brake shoes to the point where the metal strip is just touching the drum surface. it will not sound yet when going forward since the brake will adjust back to its position before backing. ang siste kasi pag nasa halfway yung adjustment ratchet between 2 teeth of the adjusting mechanism e bumabalik ulit dun sa dating setting, so it squeels only when in reverse but not when moving forward.
braking with squeaking sounds
