Results 1 to 8 of 8
- Feb 2015
- 30
June 8th, 2017 07:41 PM #1Mga paps, ask ko lang. Kakapalit ko lang ngayon ng brake pads ko sa unahan. Bakit kaya ganun? Hindi po kasi pantay yung kain ng pads. Mas makapal yung sa driver side kesa sa passenger side Ano kaya yung problema nito?
Thanks in advance.
- May 2011
- 481
June 8th, 2017 08:37 PM #2Fix the cause not the symptom.
The uneven wear on the pads was either caused by bad wheel bearings, stuck brake calipers, clogged brake hoses, restricted brake lines, frozen brake caliper pins, warped rotors, too rough brake disc surface or, in the case of Nissan cars with diagonal split brake hydraulic systems a misadjusted brake master cylinder. Have it checked by a competent technician.
- Jun 2005
- 3,774
- Feb 2015
- 30
June 9th, 2017 11:10 AM #4
- Jun 2009
- 50
June 9th, 2017 11:33 AM #5Bring you car kahit sa mga Shell gas station na may service bay. They will pull down the wheel bearing and bring the bearing sa mga auto shop to buy the new part. I think kailangan din ipa-machine shop yan para matanggal ang existing bearing at maikabit ang bagong bearing then balik na para ikabit naman ng mekaniko.
- 53,883
June 9th, 2017 12:12 PM #6
- Feb 2015
- 30
June 9th, 2017 06:02 PM #7
- Jun 2009
- 50
June 9th, 2017 06:10 PM #8
