Results 1 to 10 of 133
July 14th, 2012 10:51 PM #1
i want to make sure that the brakes of my car is in tip top condition. How do you maintain the brakes?
pls post the details here?
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 15th, 2012 12:00 AM #2I'm no expert but AFAIK best way to maintain your brakes is to change your brake fluid at the proper interval. I think its 40,000 kms or 2 years whichever comes first. Brake fluid absorbs water vapor. I forgot the correct term. I think its hygroscopic or something like that. When it absorbs too much water, it will cause all sorts of nasty things to the brake system as well as loose stopping power. So best replace at the recommended intervals.
Brake pads are replaced when its too thin. Normally you will hear a squeaking noise when its time to change brake pads.
July 15th, 2012 12:45 PM #4
July 15th, 2012 02:38 PM #5
Front pads are bigger compared to the rear pads if ever the rear braking systems has a disc brake. For the price, it depends on the brand of the vehicle. At a normal usage, the ratio is 2:1 meaning you change your front pads twice before you change your rear brake pads. Factory setting for our brake system is at 70/30, 70 for the front and 30 for the rear.
July 15th, 2012 02:58 PM #6
Thanks for your reply.
the car is L300FB. though i don't feel or hear something unusual, i thought of changing the brake pads on its next maintenance. any idea of the size/specs/brand i need to buy?
what do you mean by "Factory setting for our brake system is at 70/30, 70 for the front and 30 for the rear"?
July 15th, 2012 03:42 PM #7
Brake distribution ratio
Your rear brake for your L300 has a drum brake system. Its best to have it clean every PMS to minimize brake dust built up.
An oridnary bendix standard brake pads and brake shoe for the rear will do the job
July 15th, 2012 04:45 PM #8
Tesla Philippines
