Results 1 to 10 of 23
- Sep 2019
- 107
December 18th, 2019 08:18 PM #1Hi Guys,
Need your advice on this.
Napansin namin medyo bumababa yung brake fluid level ng car. Siguro mga 1 tablespoon dinadagdag namin every 1 to 2 weeks?
Not sure if may slow leak ba sa bleeder valve kasi pinableed namin sya last October or baka dahil worn out na din brake pads?(mag 4.5+ years na yung brake pads).
Yung father ko nirerefill nya ng brake fluid above ng konte dun sa full indicator dun sa reservoir para daw mas nakikita nya if bumababa yung level ng brake fluid. Ok lang ba yun or dapat hindi lumagpas sa full indicator? Thanks.
- Sep 2010
- 290
December 18th, 2019 08:22 PM #2
- Sep 2019
- 107
December 18th, 2019 10:31 PM #4Thanks mga sirs! Magcheck na ako ng brake pads. Might try yung brembo brake pads siguro mas mura sya dun sa original akebono brake pads ng mazda3 ko.
December 18th, 2019 11:13 PM #5
have the brake pads looked at. if the thickness is ok then its not necessary to change. the brake fluid on the other hand probably needs changing if its over 4yrs.
- Sep 2019
- 107
December 18th, 2019 11:18 PM #6Thanks sir. Kakabrake fluid change lang din nung October. Kaya naisip ko din if baka hindi nahigpitan yung bleeder valve msyado during the fluid change?
Or most likely dahil sa worn out brake prads since sobrang slow lang nung pag decrease? Wala naman ako nararamdaman na difference sa pag brake parang normal lang din naman.
I will drop by sa Speedyfix siguro sa Friday to have them check just to be sure na din. Thanks sirs!
- 53,883
December 19th, 2019 01:58 AM #7brakepads do not normally wear that fast... unless your rotors are sandpaper-lined.
my guess is, you're leaking brake fluid.
hoist the car up and take a good look around the brake lines and brake mechanisms. look for something that's wet with brake fluid. don't forget the brake master.
December 19th, 2019 11:24 AM #8
December 19th, 2019 11:32 AM #9
December 19th, 2019 03:29 PM #10
Tesla Philippines
