Results 1 to 10 of 48
January 29th, 2021 06:31 PM #1
The ABS light of my Sportage turned on last Saturday & today, I brought it to Bridgestone Alabang. Tech cleaned the sensors & scanned, no fault codes detected but the light is still on. What could be the problem? I read somewhere I can try to disconnect the battery to reset the computer. How long will I keep it disconnected?
January 29th, 2021 06:42 PM #2
A solid ABS light can mean a lot of things... it can mean low brake fluid level, faulty ABS sensor, or a faulty ABS module.
Check you user manual first. It may have slightly different meanings with different cars.
January 29th, 2021 06:48 PM #3
It could be the brake light switch.
January 29th, 2021 07:05 PM #4
*bloo
try mo if umiilaw brakelights
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
January 30th, 2021 12:03 AM #6
Sa Kia forums, to reset the abs light, unplug the positive battery cable then hold down the brakes until the electricity is drained from the ecu. Reattach the positive terminal & the light should be gone. Still thinking if I should try it.
January 30th, 2021 07:53 AM #7
ui nice to know
para palang avaya yan, need deprive ng power yung unit
January 30th, 2021 09:45 AM #10
malamang bro gamitan nila ng abs and srs specific na scanner yan to clear the codes
sana libre
Tesla Philippines
