Results 1 to 10 of 3407
    Could it be the compressor?
    Jul 2015
    Parang i notice it in the mornings.
    May 2005
    Did the check-light come on?
    At only 7,0xx kms, one morning I experienced rough/weak idle. Idle was around 800-900 rpm instead of the usual 1100 rpm. But with noticeable vibration. Later in the day, the C-E-L and traction control indicator came on with the cruise control lights blinking. If you drive the vehicle in this condition, it goes into limp mode and fuel consumption higher.
    Brought it to M.I. casa, they cleaned the throttle body. That cured the problem.
    First time to encounter a vehicle that needed throttle body cleaning at this age and mileage.
    2012 Forester SH 2.0 XS. 2.0 FB20
    Jul 2016
    Nope, the CEL did not turn on.
    On one hand, I'm glad to know that other people have noticed it too, but on the other hand, I'm a bit more wary about the build quality.
    Did the casa charge the cleaning of the throttle body to the warranty?
    May 2005
    Quote Originally Posted by variable View Post
    Yes they did. BTW, its out of warranty already.
    But you are very correct about the concern regarding the build quality. Lets say its not that great (at least for my unit). In fact, I never encountered these kind of problems with other japanese brands that are made in Thailnd. Anyway....
    Jul 2016
    Thanks for the replies, guys.
    I guess the next question really is: are the fluctuating RPMs bad for the engine or the car in the long run?
    Fellow XT owners, what oil does Motor Image use on the FA20DIT? I heard from Subaru BGC folks that you can bring your own motor oil in time for your scheduled oil change. What would be the best options available? Thanks in advance.
    Jul 2016
    It's possible. I'll try idling without the A/C on and see if the fluctuations happen.
    No variation in idle rpm speed on my XT. The normal idle rpm speed is between 700-800rpm. from a cold start, it starts out at around 1500 rpm then gradually goes down to around 1000 rpm when the blue cold temperature light turns off.
    Jul 2015
    Same here...
Subaru Forester
