Results 1,981 to 1,990 of 3407
- Jul 2015
- 9,583
July 11th, 2016 08:53 PM #1981
July 11th, 2016 09:00 PM #1982
July 12th, 2016 07:39 AM #1983
Rain X (and similar products) is not a good idea. It's like a drug, once you start using it, you need to keep using it so your wipers won't skip. It's very very hard to remove.
They are good to use in areas that are clean and not so dusty. But in our country it doesn't work so well.
- Nov 2014
- 1,269
July 12th, 2016 08:58 AM #1984^ I actually find RainX and other brands of rain repellent very, very useful. Since the water beads on the glass like it does on waxed surfaces, visibility is greatly improved when it's raining even before using the wipers. Skipping is minimal and only when there is just a little water to wipe off the windshield (like during light rain/drizzle).
I only reapply every 4-6 months or so, not really a hassle to maintain.
- Jul 2016
- 7
July 13th, 2016 05:57 PM #1985Question: is it normal for the tachometer to go from 600-700 rpm to 900 rpm (and back) while idling? my wife's mu-x just holds at a steady 900 rpm when idling.
i sometimes also feel a slight vibration (as if the car was beside a piledriver) when i'm at idle. im not sure if the vibration is just my imagination, but i'm sure about the tachometer going from 600-700 rpm to 900 rpm (and back) while idling.
it's an iL with about 200km on the odometer.
thanks, guys.
- Jul 2015
- 9,583
- Jul 2015
- 9,583
July 13th, 2016 09:34 PM #1989
Did the check-light come on?
At only 7,0xx kms, one morning I experienced rough/weak idle. Idle was around 800-900 rpm instead of the usual 1100 rpm. But with noticeable vibration. Later in the day, the C-E-L and traction control indicator came on with the cruise control lights blinking. If you drive the vehicle in this condition, it goes into limp mode and fuel consumption higher.
Brought it to M.I. casa, they cleaned the throttle body. That cured the problem.
First time to encounter a vehicle that needed throttle body cleaning at this age and mileage.
2012 Forester SH 2.0 XS. 2.0 FB20
- Jul 2016
- 7
July 14th, 2016 11:31 AM #1990
