Results 11 to 20 of 44
November 30th, 2012 11:59 AM #11
No, don't use any other types of grease. It should be capable of handling high temperature. Typically, copper grease is used to serve as both lubricant and anti-seizing compound.
I still have this lying in the garage that I use on my bikes' brake pads (back side), guide pins and anywhere it requires an anti-seize grease. I've had it for more than 10 years I think that I've forgotten where I bought it from.
November 30th, 2012 12:08 PM #12
Yes, its use is rather rare. The only place I've seen mechanics use a torque wrench on lugnuts is AutoPlus, and they're not exactly your run-of-the-mill garage. If you're interested in buying your own, I got mine at True Value, although not all the branches have it in stock and you might have to do some cross-shopping to see the micrometer type I recommend.
For Japanese cars there are two different thread pitches for lug bolts and lugnuts.
M12x1.5 is the more common variety used by Mitsubishi, Toyota, Daihatsu, Honda and Suzuki, among others.
M12x1.25, the smaller thread pitch, is used by Nissan and Subaru (I'm not sure who else).
This still doesn't explain why you had lug bolt trouble with your Subaru, though...I maintain that if torque is correct, then bad metallurgy is to blame.
November 30th, 2012 12:33 PM #13
November 30th, 2012 12:42 PM #14
November 30th, 2012 01:31 PM #15
- Nov 2002
- 1,326
- Nov 2002
- 1,326
November 30th, 2012 08:39 PM #17Nkakita na ako handyman ng torque wrench..
Duda ako d kaya yung nut ay iba ang thread spec sa thread spec ng stud?
Sa youtube on how to use torque wrench... Bale may extension bar pa then socket wrench.... Anong size ba ilan mm usually mga nut ng tires?
Yung anti seizing agent talaga san nakabili? Another one broke off yesterday as i bought rubber for the damaged one... Nasira sa banawe nung nagpalit ng gulong uli...
November 30th, 2012 08:54 PM #18
November 30th, 2012 08:56 PM #19
A torque wrench is meant to be used with a socket set, so it should be able to tighten, loosen and set torque to any bolt or nut as long as you have the socket for it. The torque wrench is the bar you're referring to - it's NOT an extension or breaker bar.
Lugnuts are measured externally by hex size. A typical cross wrench can work on four of the most common lugnut sizes: 17mm, 19mm, 21mm and 23mm. On my Jazz the stock lugnut size is 19mm hex, although I moved to 17mm to fit my current wheels and 21mm on my old ones. Hex size should not be an issue with breaking lug bolts.
If you still have stock lugnuts I doubt they have the wrong thread size. Cross-threading would usually occur if you swapped out the stock lugnuts for aftermarket ones without matching the thread pitch.
- Nov 2002
- 1,326
November 30th, 2012 09:54 PM #20Wala sa manual ng subaru yung torque settings so have to check casa siguro...
Weird lang talaga... Napuputol stud kapag niluluwagan yung nut... Yung isa nga halos totally loose na dun pa sumabit ... So higpit ng konti... Then luwag uli... A couple of times... Bumigay pa rin....
Anyway saw copper grease na sa concorde... Will get torque wrench na rin to tighten it to specs... ( i used to think na sa engine ang applicable yung ma tighten to the right torque yung mga bolts and nuts...pati pala tire studs... ).
But i think i got another step clser to just selling off this subaru...
