Results 1 to 10 of 159
December 28th, 2012 12:34 PM #1
Hi all,
Now that there's an increasing number of posters in this sub-forum, I propose that we list down the common problems we experience with our Subbies. This should exclude: (a) all regular PMS costs - e.g. change oil, filters, parts which have to be changed due to wear and tear and (b) those caused by accidents, collisions etc.
I think we can include some work done during PMS or other times if the change/repair/replacement occurs earlier than most cars - e.g. rotors which are damaged even if replaced by warranty, replacing power steering mechanisms, belts if done early in a car's life (for example, my RAV4 is more than 8 years and 80,000 kms old and this has never been done).
I hope this does not end up to be a "scare" thread, which will discourage potential owners, but a way for us to anticipate problems, propose solutions and save up on potential gastos.
- Mar 2009
- 823
- May 2006
- 1,668
December 28th, 2012 04:44 PM #3* 10k kms <- refaced front rotors for free, wiggling when braking.
* 30k kms <- Ball Joint Assembly = P4,606
* 40k kms <- V-Belt (ac and alternator belt)
* 50k kms <- power steering control valve *P26,468 + Stabilizer bushings + Steering Rack repair kit * P2,094
Impreza 2.0R 2008 M/T
December 28th, 2012 04:47 PM #4
I think it would be nice too if the poster indicates whether the unit was driven hard or calmly
Sent from my GT-P7310 using Tapatalk 2
December 28th, 2012 05:07 PM #5
Thanks for this! Most of the posters here have new cars, so it's always good to get posts from those who have driven more than 5,000 kms
Re: power steering issue
I've seen a few other owners in the subaru forums (scp and subysoc) post about power steering issues as well, starting from about 3 years onwards or around 30,000 kms. Php 30-35,000 up ang usual damage inclusive of labor.
Is your car already using the electronic power steering system or hydraulic? I think the 2012 models already have the EPS. Wonder if this problem will still hold true for the newer models.
V-Belt
How much for the V-Belt, if you can recall?
Also, from the mileage, is it safe to assume that your car is a daily driver?Last edited by April_Ryan; December 28th, 2012 at 05:16 PM.
- Oct 2012
- 196
December 28th, 2012 11:00 PM #6Good thread!
Istan were you tracking the car? 10T KM is early for a rotor reface.
AR, hope you are right about the EPS for 2012 units.
- May 2006
- 1,668
December 29th, 2012 01:23 AM #7I drive calmly, usually under 2.5k rpm, mostly under 2k rpm. Daily driven sya.
Hydraulic power steering ang akin.
* 40k kms = P36,020 <- PMS + all the fluids (atf, engine oil, gear oil, coolant) + Front Brake Kit + V-Belt (ac and alternator belt) + labor at P4k
Mga P12k ata yun V-Belt.
* desmosedici
10T km for rotor reface was early, but I can't take the shuddering when braking. After the reface, no more shuddering until now at 52k kms.Last edited by istan; December 29th, 2012 at 01:33 AM.
December 29th, 2012 10:52 AM #8
Just 2 weeks after I bought my FXT, I noticed some rattles coming from the tailgate and rear seats. Very minor but an irritant considering the car was brand new. Had all these checked during my 1600 km check-up and after some tightening of screws and bolts, the rattles were gone. Not sure if that's a common problem, but if several other owners have experienced it, then I guess it can be considered as common.
- Mar 2012
- 32
January 6th, 2013 11:32 PM #9i had to replace a hub bolt at 7000km... only found out about it when i went for a tyre rotation, unfortunately it was the 31st of Dec so walang makunan ng piyesa... had to drive it with 4 bolts only, safe pa naman sya
loose thread na, di matanggal through usual means so i had no choice but to force it out
i've lost 2 lug nuts on my front right rim already kahit naka-torque sya nang maayos... had to buy a torque wrench... napansin ko lang yung 2 lumuluwag parati look totally different from the ones na walang issue... hayz...
i drive it hard... i mean really hard... 5 track days in 7000km... it's a 2.5LGT nga pala...
January 7th, 2013 01:53 AM #10
^wowiesy complained about wheel studs earlier. is it the same thing? here's the thread -->http://tsikot.com/forums/subaru-cars...el-stud-91082/
- - - Updated - - -
Tesla Philippines
