Page 183 of 591 FirstFirst ... 83133173179180181182183184185186187193233283 ... LastLast
Results 1,821 to 1,830 of 5910
  1. #1821
    relax lang flakez... explain mo na lang sa erpat mo. Or pabasa mo na lang dito.
    Apr 2004
    #1822
    Meron ako nakita na duster sa SM na parang CCD at waterblade na parang yung sa CCD din. Kasama ng mga demo products nila. Pati microfiber meron. OK kaya mga ito? Yung duster, instead of wax some sort of silicon daw ang nakaembed sa strands niya (less than P1K). Yung waterblade, silicon construction din daw. Yung microfiber, you get 4 towels for P400+.
    #1823
    Quote Originally Posted by frankosiz
    nice link..
    kaso I'm not gonna wash my car directly under the sun.
  4. #1824
    RafRaf: Nothing beats the Original California Car Duster, think of it as an investment - it will last you around 5-6 years even without washing, just don't drop it. Sa Microfiber naman, get the Microtex available naman to locally.
    BTW, Autoplus, the local distributor of Mothers will also sell CCDs, abangan mo na lang sa transport show, I think they'll have a booth.
    #1825
    nagkaroon nang bird poh yung car ko. Matagal sya bago nalinis at natanggal yung bird poh mga 1 week siguro hindi kasi napansin eh. Hindi kasi nagamit.
    Nung nilinis nagkaroon na nang bakat yung bird poh.
    Paano sir sya matatanggal.
    Thanks.
    #1826
    yikes.. baked and etched already into the paint. that's one of the reasons why I don't let those sit on the paint for too long.
    depending on the severity, polishing (DACP) or several applications of a scratch remover would greatly reduce the appearance of that defect. im a bit wary though that it might have eaten already through the clear. just make sure to rewax the affected part afterwards.
    what i did before to get rid of a similar but extensive defect is to wet sand it. but mind you, I don't like to recommend wet-sanding to everybody because it thins the clear considerably and you have to be skilled and confident enough with your buffing skills to remove the sanding marks left by wet-sanding.
    #1827
    mukha nga it already eaten the clear coat
    Pwede na ba yung 3M scratch remover? then I will wax it off na lang.
  8. #1828
    hindi kaya by hand yan, you'll need a rotary for that.
    #1829
    Quote Originally Posted by CLAVEL3699
    yup. hand-applied. but you have to make several applications to get a discernible effect.
    good luck. hope this helps.
    #1830
    rubbing compound kaya na kaya?
    I will do it not ot hard?
