Results 551 to 560 of 1645
August 10th, 2005 08:51 AM #551
Are the rear seps on the rear doors? Kasi talagang sa harap dapat nangagaling ang sound. Tanong nga dun sa kotseaudioclub, pag nanonood ka ba ng sine/concert, san ka nakaharap? So for rear passengers, dapat nasa door, near the B pillar. Pero kung nasa likod, above the trunk, rear fills will do the trick which doesn't necessarily have to be separates, and sometimes not needed depending on listening preferences.
20K for the sub and amp puwede na... But you will have to get a 4 channel amp to power the front seps and the sub. You will need another channel to power the rear. Bihira ang 6 channel amp.
- Feb 2005
- 22
August 10th, 2005 09:27 AM #552the wildthing,
sa rear doors mounted ang speakers ko. Nanghihinayang kasi ako kung di ko mapalabas yung quality ng sound ng separates.3 days old pa lang yung separates ko sa rear. Ill write my options. Need help to decide.
My options:
1. maintain the front seps , remove the rear seps , put 1 amp for both the front seps and sub (i can sell the sep. or trade)
2. Option 1 + 3 way speaker sa rear ,separate amp for the seps and sub
3. Maintain front and rear seps and put 2 amps for the seps and sub.
Note: Sa fieldmaster ko kasi mahina rin tunog sa rear kaya iniisip ko baka hindi practical naka sep. sa rear kung di rin lang lalabas yung quality ng sound like in front.
Thanks.
August 11th, 2005 01:57 AM #553
It is possible na underpowered... amp nga siguro. So you need a four channel amp for your front and rear seps, then a separate amp for the sub. At 20K, you might want to go for the Fentons or V12s in Raon, and a good sub. Or you may just want to spend 20K for the 4 channel amp, wiring and install, maganda na yan, wala lang bass muna.
- Feb 2005
- 22
Tsikot Member Rank 3
- Jul 2004
- 1,540
August 16th, 2005 10:49 PM #555thank you sa mga nagsuggest. Naayos ko na set up ko. Asa kabilang thread na.
August 17th, 2005 03:44 AM #556
Originally Posted by the_wildthing
- Aug 2005
- 2
August 23rd, 2005 08:37 AM #557mga sir ask ko lang kung magkano subs na JL 10W7 series. at san makakabilli d2? mas makakamura ba ako kung magpapadala ako from states or bili ako d2 kung may authorized dealer na d2 for this subs. tnx mga gurus.
*newbie lang po. dami kong natutunan sa forum na 2. very informative for a novice like me. tnx po ulit.
August 23rd, 2005 11:16 AM #558
roldo88: JL 10W7 will set you back around 30K - up if am not mistaken, you can source it thru DBAudio, check out the "advertise" section of www.kotseaudioclub.com
- Aug 2005
- 2
August 27th, 2005 06:18 PM #560
guys question: can i use my stock speakers as my tweeters... will this do or do i really need to buy one... btw, i already have a sub (salvaged from my uncle) 1 pc. targa 15" with box and i plan to use my stock HU, what else do i need to buy para ma-set up ko sasakyan ko? may ampli na me na makukuha from my uncle who gave me the sub, kasama daw nung sub nung binili nya yung sasakyan nya kaso sira daw isang ch. nito... san ko po pwede kaya pagawa? hope someone could enlighten me with my prob... nga pala, my vehicle is a 02 mitsu adv. ss model...
Tesla Philippines
