Page 47 of 165 FirstFirst ... 374344454647484950515797147 ... LastLast
Results 461 to 470 of 1645
    Feb 2005
    #461
    question lang po. anu po purpose ng seps? iniisip ko kasi kung ako lang b na hindi na magpakabit ng seps, at subs lang ilalagay ko. stock na lahat.
    Mar 2005
    #462
    -aces_fan-
    actually ok lang yan. pero for listening pleasure kasi kung magpapalit ka. mas malinaw sya... yung mga drum beats maririnig mo ng mas malinaw...
    Feb 2005
    #463
    ah... e ang mga rear speakers po? ok lang din ba na stock yun?
  4. #464
    You can go with Coaxials.
    Jan 2004
    #465
    aces_fan: I actually started with stock speakers and a sub... Then separates a bit later to replace the fronts with separates. I disconnected the rear speakers. You can actually live without rearfills. Pero kung trip mong meron pa ring naririnig mula sa likod, ok na rin to have coaxials.
    Feb 2004
    #466
    for a beginning system, i would suggest you get a 4channel amp with built in crossovers, and get a 10 inch sub.
    use the front two channels to power your stock front speakers with your crossover set at about 70 or 80 hz. they connect your sub to the bridged rear channels of your amp with your crosoover set to 80hz or 70 hz and down. this will be sufficient. when you have money again, replace your front speakers with separates. when you have more money, you can invest in a dedicated subwoofer amp and another 10 inch sub, para pair na.
    dahan dahan lang. just make sure that the pieces you purchase can be integrated in your future system.
    Feb 2005
    #467
    thanks guys.
    #468
    curious lang....i dont know much about sound set-ups, how do you connect a single sub to a 2 channel amp???m parang series ba (Left(-) to right(+), then right(-) and left(+) to subs)
    May 2005
    #469
    ok ba yung seps na JBL??
    tsaka meron bang coax speakers na bilog? usually kasy 6x9 nakikita ko eh..
    tia!
    Jan 2004
    #470
    Quote Originally Posted by trup
    If the amp is bridgeable, you can connect the + of one channel and the - of the other channel into one sub. Whether it's bridgeable or not and what load it can handle is in the manual. If you don't have it, try searching google for it. HTH.
audio set-up for beginners (ARCHIVED)
