Results 2,541 to 2,550 of 2560
- Apr 2024
- 25
June 25th, 2024 01:15 PM #2541Servo still gamet ko kapag idle ko 1.8rpmi then nag hung 1.3rpmi saan ko pwede adjust para instead sa 1.8vrpmi sa 1.5 rpmi nlang then sa 1k nlang sya mag hung, pwede ba sa fix sas papano left or right? Sana may maka pag share
- Jun 2011
- 1,190
June 26th, 2024 12:39 AM #2542Kung bago na ang throttle body at servo motor,
ang next suggestion i check sa YT search ay.
1. Fuel filter kung barado
2. PCV valve or hose
3. Vaccum hose na may leak, gaya sa brake booster
- Apr 2024
- 25
June 26th, 2024 09:31 AM #2543
- Mar 2008
- 53,883
June 26th, 2024 10:17 AM #2544sounds like a defective idle-up system.
and by your cuento, mukhang intermittent yung defect.
and the problem persisted even when you replaced the servo? hmmm....
i read before, that some car owners simply bypassed the servo by installing a mechanical actuator...
i read somewhere, that some altises have an unusually high idling rpm when started cold. they traced the problem to a leak in the intake manifold gasket.
- Apr 2024
- 25
July 16th, 2024 06:02 PM #2545
- Mar 2008
- 53,883
July 16th, 2024 11:04 PM #2546
- Oct 2024
- 6
October 8th, 2024 10:21 PM #2547Hello po, bago pa po ako dito. May binili akong lancer 96 in good condition pa, pero normal po ba yung steering wheel na mahirap paikutin if naka steady lang yung sasakyan? but if the car is moving na kahit mabagal lang, madali lang ito paikutin. Is there power steering in this car or wala? Oh baka sira lang yung power steering niya. Thank you!
October 8th, 2024 10:44 PM #2548
- Mar 2008
- 53,883
October 8th, 2024 10:47 PM #2549yes and no.
the lancer of that era came with pawis steering or with power steering, depending on the variant.
based on your story, your car probably does not have power steering.
motortrend is right. look for it, po, if you have one. in those days kasi, most PS were hydraulic and had PS fluid.
google if you do not know what it looks like.Last edited by dr. d; October 8th, 2024 at 10:51 PM.
- Oct 2006
- 6,091
October 9th, 2024 09:12 AM #2550
Tesla Philippines
