Page 94 of 96 FirstFirst ... 448490919293949596 LastLast
Results 931 to 940 of 954
    Jan 2009
    #931
    It's been a long while since I experienced failure of the actual optical sensor. If it's not dirt or anything mechanically wrong with it, yung sensor na mismo ang problem. In which case, it's e-waste.
    But kung skipping scroll wheel or double-clicking/intermittent buttons lang, I fix it myself. Dami sa online ng replacement rotary encoders and mouse button switches. Just get the correct one and choose the good kind... TTC or ALPS for the rotary encoder and Kailh for the switches, para tumagal.
    Some Logitech mice use optical scroll wheel sensors (instead of encoders). They don't technically wear down, but my experience with them is that they sometimes get dirty (due to the grease from the wheel mechanism mixing with grime from your hands) and blocks some of the holes where the sensor beam goes through. This results in skipping and jumping when turning the wheel. I just wash it in joy to remove the dirt buildup.
    Currently, I'm using a Logitech M585 and a couple of Rapoo M500 mice. All are wireless (w/ dongle) + multi-device BT capable.
    May 2019
    #932
    Logitech M331 which is wireless and M337 which is bluetooth. I just had 1 M331 but it has a clunky scroll wheel now. M337 bluetooth has stuttering sensor at the bottom and this is my 5th M337, including the others I bought for my family.
    Lagi ko problem is yung sensor sa ilalim nag stutter or hang after a year or 2.
    Sent from my SM-S918B using Tsikot Forums mobile app
    Logitech M331 lang din tumatagal na mouse sakin.. Ang tibay kahit lagi ko naibabagsak.. Tatlong beses na ito ang lagi ko binibili, umabot ng 3 years yung last kong bili, yung ipinalit ko same pa din pero sabi sakin discontinued na? Last piece na daw yung nabili ko, meron na daw mas latest ang tech..
    Sep 2010
    #933
    What’s a cheap MacBook (what year?) nowadays for my son? He’s just in Grade 6 so just basic stuff like office, Google classroom, YouTube etc.
    #934
    Thinking of buying this. Vertical mouse, although wala naman ako problem sa wrist but is it true na mas maganda sa posture ang vertical mouse?
    Is vertical mouse claims real or just a scam? Click image for larger version.
ID:	44682Click image for larger version.
    Jan 2010
    #935
    What's your budget? Are you willing to buy used? Btw, why choose a MacBook if the curricula is on Google classroom?
    Sep 2010
    #936
    Yeah just a second hand one. Ah most of us at home are using Apple so easier to be in the same ecosystem, & airdrop is very convenient. Plus his previous laptop is a MacBook Air. Easier for him to use.
    Jan 2010
    #937
    A used M1 Macbook Air is about 29k-35k these days. FB Marketplace is likely the cheapest place to find one (caveat emptor). Brand new old stock sealed M1 Macbook Airs (2020 usually) can be bought for about 36k to 40k these days, Greenhills is a good source but do haggle. Sa FB marketplace meron din yata but you will have to look around for trustworthy sources.
    I would be willing to swing up to 31k for a used M1 Air as any price higher than that I would prefer to get the new old stock instead.
    Intel Macbook Airs can be had for 15k to 25k depending on the year and condition. Macbook pros are heavier, as you know, so I don't prefer getting one for kids. The intel ones with the touch bar are probably going to be 21k at least.
    If budget permits, I would recommend M1's over the Intel variants because these will likely get longer software updates. And the M1's are much much faster too, as you probably know.
    #938
    Kung malaki kamay o palm mo, at for cad modelling, video edting, animation use, okay cya.
    Kung small to mrdium size lang palm mo, and for ms office use, and browsing lang, get the MX Anywhere 3. Karamihan sa gumagamit ng vertical mouse in their work may second mouse yan na flat design, isang usb plug isang bluetooth.
    For the posture, nasa computer chair yan. Yung may magandang back/ lumbar support, mahal nga lang nasa >10k mostly.
    Sep 2010
    #939
    Thanks for this! Appreciate the helpful inputs!
    #940
    I guess I don't need it then, thanks.
Computer and Laptop Tech Thread
