Page 314 of 320 FirstFirst ... 214264304310311312313314315316317318 ... LastLast
Results 3,131 to 3,140 of 3192
    #3131
    Quote Originally Posted by waver View Post
    Hi fellow Jimny owners, maybe you can help confirm. CASA is claiming that Jimnys (mine is 2017 model not the new one) have no aircon filter. May abang lang daw. So they recommend magkakabit daw sila aircon filter . Just wanted to know if its true that Jimny indeed had no aircon filter before. Thanks
    Sent from my CPH1609 using Tapatalk
    this is certainly not suzuki-related, but
    my first gen innova did not have one, either.
    the local aircon man in banawe cut a window on the plastic housing, so's i can place in it the air filter element.
    i hope yours already has this window, so's you do not have to cut to make one.
    Oct 2014
    #3132
    Thanks Dr. D.. I thought all cars nowadays have an aircon filter and casa was trying to pull one of me.
    May abang naman na daw.. I guess I'll have it installed then.. I think its better to have one than not have one
    Dec 2019
    #3133
    Yes, Suzuki PH has switched to Indian-made Jimny
    Suzuki Philippines has now officially made the switch: their popular mini 4x4 model, the Jimny, will no longer be sourced from Japan. Instead, Philippine-market Jimny units will now come from India. It was confirmed to us by a senior representative of Suzuki Philippines after Indian-made Jimny units started appearing at Suzuki dealers all over the country.
    #3134
    Spot the difference[emoji851]
    NonVVT M13A Click image for larger version.
ID:	42561VVT M13AClick image for larger version.
    #3135
    And a VVT M15A upgradeClick image for larger version.
    #3136
    If you have a pinging/knocking M-engined Suzuki, check your knock sensor on the block under the intake manifold, between the alternator & the starter. Chances are the resin cover is gone.
    One might easily be tempted w/ cheap replacements, but only use GENUINE for this sensor.
    On a JB43, this can only be accessed by removing the flexible intake hose & the alternator....way easier & simpler than the shop manual way of taking the intake manifold off, requiring new gaskets.Click image for larger version.
ID:	42856Click image for larger version.
    #3137
    Broken vent blade? Easy fix... Paper clip + baking soda + superglue + touch up paint.[emoji4]Click image for larger version.
ID:	43373Click image for larger version.
    Jun 2011
    #3138
    Salamat! Curious, para saan iyong baking soda?
    #3139
    Quote Originally Posted by bxr monkey View Post
    It's a moving part. Superglue alone won't hold for long. A bit of baking soda around the clip + a drop or 2 of glue turns it into a solid resin tougher than epoxy.[emoji4]
    Jun 2011
    #3140
    Ayos. Parang reinforced concrete.
Suzuki JIMNY [merged threads]
