Results 851 to 860 of 954
- Oct 2021
- 35
April 1st, 2022 01:23 AM #851You can save a few bucks if you get an intel cpu without the 'K' at the end if your son will not do overclocking
I suggest to get something like 850w or higher power supply. And check the unit if it is on the high-end side. This is a must considering that your pc parts are also high end.
PSU Hierarchy (Mar. 2 22) - Power Supply Unit List
Sent from my HD1900 using Tsikot Forums mobile app
April 1st, 2022 02:54 AM #852
Id go with WD Black SN 770 1Tb. its the latest from WD. It has the lowest latency if competitive gaming.
For memory Adata XPG 6000 CL40s are better than those aorus sets. They are somewhat highly desirable in the overclocking scene. I checked its compatible with the z690i ultra.
for gpu go for zotac or galax.. same drivers.. you can use MSI afterburner to overclock these.
tiny picture kasedamn that low res.. hahaha
- Nov 2017
- 287
April 1st, 2022 09:44 AM #853Thanks sa mga inputs.
What are your thoughts on ADATA Gamix S50 Lite NVME? Its 40% cheaper than Aorus 7000S.
I also check the DDR5 Corsair 5200 CL40 and its cheaper than the Aorus for this 2x16gb. Is it also a good choice?
For power supply, looking at Corsair RM850 or RM1000X. Or the Gigabyte P1000GM. Still figuring out, inputs are very much welcome.
April 1st, 2022 01:06 PM #854
Like they said ... DDR5 is expensive for now ... diminishing returns ... you also don't need a high spec CPU for gaming ... most of the work is done by the GPU ...
April 1st, 2022 02:45 PM #855
5200 CL 40 are ultra slow mems. I'd go with ddr4 32gb 3600 CL 16 in the 10k price range. (ddr4 motherboards are plenty)
Best RAM for Intel 12th-Gen Core: DDR4 vs. DDR5 | TechSpot
- Jun 2007
- 187
April 1st, 2022 03:54 PM #856I'd go with a Ryzen 9 5900 or 5950 and then upgrade the gpu to a 3080ti instead or 3090 gaming is all about the gpu... Just my 2 cents
Sent from my M2012K11AG using Tsikot Forums mobile app
April 2nd, 2022 02:40 AM #857
April 2nd, 2022 02:41 AM #858
April 2nd, 2022 01:52 PM #859
Intel is king again ... AMD is back to being second ... So get Intel CPU ...
April 2nd, 2022 04:17 PM #860
