Page 34 of 96 FirstFirst ... 243031323334353637384484 ... LastLast
Results 331 to 340 of 954
    #331
    Some are now using USB typeC
    Sana lahat ng laptop maging type C na. Para isang charger nalang for phone, laptop, and everything else.
    Right now both my X1 and MBP have type C ports, so when traveling I only need to bring one charger.
    lakas ng benta ng ryzen5 4500u laptops sa market. ryzen 4000s in general ...
    #334
    [emoji28]
    I remember in the late 90s. 16mb of ram. We will convert few mb to a virtual drive . And then copy the game diskette to that virtual drive para mabilis ang game. At hindi na kailangan yung maingay na pag read ng diskette. [emoji23]
    Jan 2016
    #335
    Keen or Bumpy? [emoji38]
    Jan 2009
    #336
    Anyone using a Ryzen 5 3600? How much of an overclock were you able to squeeze out of it?
    I was only able to get it stable at 41.75x on the multiplier (from stock of 36x) * 1.28V. In the real world, it's doing 4.17 GHz on all cores. It's stable on Prime95, Blender, OCCT, and FAH. Cooler is a DeepCool GAMMAXX 400 V2.
    I know I can push this further but I think the cooler is the limiting factor. As it is, my thermals are already peaking in the low-mid-80's out of the 3600's max temp of 95°C. That said, I'm sure it would've ended up with much worse performance if I used the stock Wraith Stealth cooler. Maybe I'll switch to a Noctua NH-D15 or U12S or even the venerable U12A. That would tide me over until I've saved enough gas money for a 3950X.
    Call me old-fashioned but I still have a disdain for AIO coolers... it's got one too many moving parts that can fail. High-gain, high-risk. Give me a massive CPU air cooler anytime.
    Dec 2009
    #337
    ^What's your motherboard?
    Jan 2009
    #338
    Gigabyte B550 AORUS Pro.
    Jul 2013
    #339
    In a way, nakaka-inis din yung Type-C... kasi not all are the same.
    Yung charger ng T495s and MacBook Pro ko ang lalaki...
    Tapos yung PowerPort Atom na gamit ko dati sa MacBook 30W lang pala. so di nya kaya icharge yung both laptops ko ngayon...
    Naghahanap tuloy ako ng 100W++ na GaN charger.
    Dec 2009
    #340
    It's a gaming mobo so I suppose the VRM thermals are good but then again reviews on YouTube show otherwise MSI bazooka turned out to be better than gigabyte AORUS with B550 chipset..monitor also your VRM temperatures..it takes 4 to tango in terms of overclocking a PC Power supply, VRM, CPU and the cooler
Computer and Laptop Tech Thread
