Page 299 of 307 FirstFirst ... 199249289295296297298299300301302303 ... LastLast
Results 2,981 to 2,990 of 3070
    Feb 2015
    #2981
    try Egghead Audiohub, maybe you can find a DAP to match your 10k budget [emoji848]
    do you still have hi-res music in storage? i was using a DAP before (a Fiio) but not anymore. i used as source the smartphone now with music streaming Spotify.
    Yep. Unfortunately my integrated hu is quite limited and can only play mp3s.
    What unit did you use? I think the dsp2 has an optical in which I plan to use.
    Mar 2019
    #2982
    Para saan po ang wire na violet with red stripe sa stock head unit ng innova j? Naka hiwalay sya sa main power harness, sya lang ang nag iisang wire sa 20pin connector
    Sep 2008
    #2983
    What would be a recommendable single DIN headunit that is in the market? I was hoping to get a wooden finish plate to replace my current one (Blaupunkt) but I doubt if there is still one in the market. I might have to replace my current one as the LCD cannot be read anymore maybe due to old age (it came with the car when bought new).
    Dec 2007
    #2984
    Quote Originally Posted by [archie] View Post
    theres nothing wrong kung limited ang budget sa setup. just do it right and im sure nakangiti ka nakikinig. hehe
    i'm also a believer on this and i concur. kahit limited ang budget but you have maximised the potential of the setup, you can still enjoy the sound quality. my advice to aging people and those who have already defeciencies in hearing but would still like the sound of music, have your ears checked by an audiogram to identify which frequencies you can compensate on your setup. kahit anong mahal nag setup but the ears has already problems which has never been identified in what area of the spectrum, is still useless. this i learned from an audiophile friend. and in the modern times, DSp is your friend.
    Apr 2012
    #2985
    Quote Originally Posted by jakewise View Post
    for reference,
    Single DIN | Product categories | Mickey's Autosound
    Sep 2008
    #2986
    for reference,
    Thank you, I'll look into it
    Feb 2017
    #2987
    Mga boss, kaya ba ng 10th gen na civic yung 2 amp set up (isang mono at 4 channel) na stock alternator lang at walang extra battery? Eto nakalagay ngayon 12" jbl subs powered by gmd9601. JBL seps at stock speakers sa likod. Balak ko lagyan ng gmd9604 para terno sila ng mono amp ko.
    Sent from my SM-T705 using Tapatalk
    Dec 2007
    #2988
    Quote Originally Posted by zero3 View Post
    No problem specially if you are using thick gauge power wires.
    #2989
    Question lang po, may mahinang white/static noise sa speaker ko. May subs with mono amp po ako at palit ng component at coaxial ang mga speakers with 4channel amp, nakakonek din po sila sa equalizer, tapos stock head unit. Kung magpalit po kaya ako ng 2din na head unit, possible mawala yung noise? Thank you.
    Dec 2007
    #2990
    Quote Originally Posted by andrewnathaniel View Post
    Kailan ma trace muna nang isang audio installer kung saan nanggagaling ang static. Pwede yun amp, gound wire, signal cable, equalizer, HU ang reason kung bakit ka may static. Hindi kase 100% sure kung head unit mo ang reason.
audio set-up for beginners [continued]
