Page 283 of 448 FirstFirst ... 183233273279280281282283284285286287293333383 ... LastLast
Results 2,821 to 2,830 of 4475
    #2821
    Open driver's window ...
    Open door ...
    Get out of vehicle ...
    Close door ...
    Reach inside thru the window ...
    Lock the door using inside switch ...
    Close window ... Remove hand quickly ...
    Test this with someone inside just to be sure. When I leave my wife in the car with the engine running she usually locks the doors from the inside. I tried using the remote to unlock the car and it didn't work. She had to unlock it from the inside.
    Dec 2017
    #2822
    Excellent advice! We don't want to be "left outside".
    [emoji3]
    I guess the "key" is the way for it, although I haven't tried it yet.
    Sep 2006
    #2823
    Open door ...
    Close door ...
    Sounds good, doesn't work (trump voice) , at least for the Mazda 3.
    Nov 2017
    #2824
    My M3's odometer reading will be at 10,000 km in a few weeks (current reading is 9200+). This will be its 2nd PMS which will be 2 mos earlier from the planned 12 mos PMS. The first PMS was done at the 1st 6 mos (odometer was around 4000km).
    Now I'm wondering which PMS will be applicable. Will it be same for the 1st 6 mos PMS which covers engine oil and filter change? Or would it be the same for the 12mos PMS which will include cabin and air filter in addition to the engine oil and filter change?
    I read from the M3 maintenance guide that the fuel deposit cleaner is used for every 10,000km. Will this be included in the Yojin free PMS?
    #2825
    there is rattling on the driver side during hard acceleration on not so smooth roads. noticed this a few weeks after switching to prokits. does anybody here know whats happening?
    #2826
    You're on 12th mo/20k yojin which should include intake & cabin filters. Your call whether to install or store. Deposit cleaner will be out of pocket, sir.
    Nov 2017
    #2827
    I checked the engine air filter as well as the cabin filter. Both seem to be still in good condition. I'll probably just keep them until the car reaches 20K on the odometer.
    Thanks sir for the info!
    #2828
    Quote Originally Posted by techd View Post
    Check if everything is torqued to spec. Did you install spring protectors? You should be enjoying the car more w/ Prokits.....not hearing noises.
    Aug 2016
    #2829
    The next gen Mazda 3 is nowhere near the Kai Concept.
    219 Mazda3: Here's An Early Look At The Production Model Through Official Drawings | Carscoops
    Sent from my Nokia 3210 using Tapatalk
    Nov 2017
    #2830
    Quote Originally Posted by RedlineJunkie View Post
    The new SkyActiv-X engine is enough for me to get excited with the new M3. I wouldn't mind if the upcoming model will not be significantly different from the outgoing model, e.g. a better front grill design similar to the new Mazda6, better infotainment system with Android Auto and Apple CarPlay, significant reduction in NVH.
All New 2017 Mazda 3
