Page 70 of 129 FirstFirst ... 206066676869707172737480120 ... LastLast
Results 691 to 700 of 1286
    Mar 2018
    #691
    Good day mga sir/mam,
    Ask ko lang if may naencounter na kayo sa nissan navara niyo na kapag aapakan nyo yung clutch para magshift from 1st to 2nd gear, sa kalagitnaan ng pagapak nyo may biglang kakalampag ng malakas.di ko malaman kung sa saan nanggagaling eh, pero yung tunog nya eh parang nabangga ka sa likod.eh sa mga iba namang sasakyan na manual di ko nararanasan yung ganun.thank you in advance sa mga feedback!
    Nov 2017
    #692
    Quote Originally Posted by harniel.metin View Post
    Ano model navarra nyo sir
    Mar 2018
    #693
    Quote Originally Posted by maxpedition View Post
    good eve sir,
    Nissan navara np300 el calibre MT.nabili sya nung feb 2017 sir.
    Jun 2016
    #694
    Hi po mga sir's,
    interested po ako bumili ng navarra this coming month.
    Nabalitaan ko po na yung mga bagong navarra sa ibang bansa is improved na yung suspension.
    meaning po ba nun yung bagong navara po na supply dito satin is improved nadin yung suspension?
    thanks a lot po
    May 2008
    #695
    Ganyan rin sa akin, July 2015 NP300 Calibre EL M/T. Parang observe ko kapag mali timing ng clutch ko
    May 2008
    #696
    Quote Originally Posted by blacksilver323 View Post
    Below from other forums is not for Navara nor Nissan but it seems that it also happens to other vehicles
    Condition/Concern:
    While driving in a steady slow speed parade type situation a clunk-clunk noise from the driveline may be heard when depressing and releasing the clutch pedal, between shifts or quickly depressing and releasing the throttle.
    Recommendation/Instructions:
    The noise is a normal torque reversal in the driveline and a combination of axle backlash, front and rear drive shaft rubber isolation flanges, drive shaft center support, and a dual mass flywheel all working together. This is a normal characteristic and not a condition of operation concern. No repairs should be attempted.
    Apr 2010
    #697
    ano ang OE part # ng oil filter and ano ang pwedeng alternatives?
    other parts na rin like air and fuel filters, parang wala sa manual kasi
    May 2008
    #698
    Steering column assembly sir ang maalala kong nakalagay sa diagnosis. But I'll double check yung ibinigay ng casa na naka-itemize yung ginawa at findings pag-uwi ko just to be sure.
    Just to provide an update for the "LAGUTOK" issue on the NP300 Navara's steering, it was finally resolved (after 2 years) on my unit but was not the same part/s as the initial findings. The parts replaced under warranty are the RACK & PINION (GEAR & LINKAGE PWR) and STEERING JOINT ASSY. It is already 6 days since it was released from casa, and so far, no signs of lagutok yet. It also took 2 days for the casa to replace/repair the mentioned parts.
    Aug 2017
    #699
    Meron pa rin kaya ito sa 2018 units?
    May 2008
    #700
    what's the topspeed of the np300 EL calibre 7 a/t?
Nissan Navara NP300
