Results 2,551 to 2,560 of 3575
- Aug 2015
- 862
September 15th, 2015 09:30 PM #2551For me rear, follow the experts nalang lalo na rainy season. This advice covers all kinds of vehicles, whether front, rear, awd or 4x4 capable.
Most likely scenarios:
Front wheels are turned pero dumi direcho kasi madulas. Understeer.
Rear wheels lumiliko kahit gusto dumirecho Oversteer. Sa sobrang liko pwede ka umikot.
Mas madali i control ang understeer all day.
September 15th, 2015 09:41 PM #2552
Maybe sir but in my experience as i had a accident long ago. My right rear tire took off from my car. D naayos nun nag vulcanize yun pagkabit and i was running like 80kms i did not spin coz i had control of my steering but only swerved until i stopped. And once also my front left tire blew out on me and boy the steering was heavy and hard to control the car lucky that i was only going about 50kms that time. So with that experience in hand. It's better to blow a rear tire than a front tire sir.
- Aug 2015
- 862
September 15th, 2015 09:59 PM #2553Nako sir ung blowouts e mejo unpredictable talaga yan. Lucky you.
Pero what im saying on the other side is exactly like your 2nd accident. You still have control somewhat kasi na i-i steer ang front e. Pag nag skid yung rear fishtailing na yun. Mas ala kang control dun.
Havent tried it personally though. Ayaw ko kasi ng pabalik balik so ipon then palit 4 na gulong.
September 15th, 2015 10:21 PM #2554
How can you control sir kung ang may problema is yun steering po? Mas mahirap po control kung front kesa rear. Yan po na experience ko sir. While the rear only follow thru sa direction nang front unless may skid effect because of slippery roads. Unless po kasi ma experience nyo sir d nyo malalaman yun difference between a front blow out at rear blow out po. Sa front po kasi heavy steering na while a likod you won't even feel you lost a wheel agad like sa front ramdam nyo agad iba na takbo nang kotse.
- Aug 2015
- 862
September 15th, 2015 10:39 PM #2555Sir diko naman kayo pini pilit. Nagtanong po kayo, nagbigay ako ng expert opinion (from michelin) a few posts back that I agree with, and that is rear daw. You can watch youtube din.. napanuod ko na kasi. I mentioned skidding, and I also mentioned rainy season earlier. Ayaw ko ma experience yung na experience nyo, so susundin ko ang opinion ni tire maker. I guess we can agree to disagree and move on...
September 16th, 2015 07:43 AM #2556
- Jul 2015
- 25
September 20th, 2015 09:32 AM #2557Sirs, pansin ko na medyo matigas na yung clutch pedal ko. Nangangawit tuloy left leg ko kapag babad sa traffic. Paano po ba ma adjust o maayos yung clutch pedal?
- Mar 2008
- 53,883
September 20th, 2015 09:46 AM #2558- - - - - - - - - - - - - - - - - - - - - -
wear and tear po.
replacing "worn components" inside the transmission housing, will probably revert the lightness and smoothness of the pedal to as brand new.
but it won't be cheap. labor alone, to open 'er up, is already expensive.
but try to see if the pedal needs lubrication first, before thinking of the trans. it might do enough to soften up the pedal.
if the car uses a clutch cable, replacing it with a new one may soften the pedal.
but if the car uses hydraulics for the clutch, as i suspect toyota does, pedal lubrication and transmission components replacement lang ang choices, po.Last edited by dr. d; September 20th, 2015 at 09:51 AM.
September 20th, 2015 10:30 AM #2559
September 21st, 2015 07:19 PM #2560
