Page 236 of 270 FirstFirst ... 136186226232233234235236237238239240246 ... LastLast
Results 2,351 to 2,360 of 2693
    Mar 2015
    #2351
    At saan po ang point of origin mo sir?kc pag long driving ako 450-550km
    Jun 2008
    #2352
    Quote Originally Posted by cliford27 View Post
    From Calamba Laguna - Naga - Legaspi Albay and back...
    Jul 2014
    #2353
    Need your help guys..
    Anyone can help me to locate where is the detect light wire (reverse gear signal) for montero stock AVT 6923 HU? TIA.
    Back of HU.
    Back of HU.
    May 2008
    #2354
    mga sir na naka gls-v a/t ask ko lang po kung normal ba na parang may clicking sound na nanggagaling sa baba ng steering wheel when you're shifting from"P" to "D" or "R" vice versa
    May 2008
    #2355
    mga sir may tnong po ako about sa auto tranny natin kung pano po ba ang proper way na pag gamit kasi i know pag ito ang nasira napakamahal nito, pag traffic po ba oh kaya nasa stop light ka dapat po ba naka "N" neutral ka habang hindi pa umaandar, and kunwari nasa parking lot ka lang naka idle ng matagal with a/c on dapat po ba nasa "N" neutral din po ba siya oh sa "P" park po?
    Jun 2015
    #2356
    Good PM all! Quick question about our Multi Info Display, I have 2015 GLS V and intermittently walang display ung MID ko, no display on fuel range, km/l, no temp etc... even the TPMS is not showing. Before it takes few minutes before the display shows, now it takes almost an hour, minsan wala talaga after driving for an hour and have reached the destination. Any idea why? Has anyone of you experienced this? I have read in the previous pages that there is a lag experienced in the display pero nag improve din.
    Jun 2015
    #2357
    to clarify, it is the data that is not showing, everything else is working such as bluetooth, usb, radio, gps and all, except the default Multi Information Display
    #2358
    Quote Originally Posted by aaairzzz View Post
    Go and let casa check your unit sir. Under warranty pa naman yan.
    Jun 2015
    #2359
    Quote Originally Posted by jasonbt_2003 View Post
    question lang, napansin ko kapag umaarangkada ako sa mga pataas at binitawan ko bigla yung accelerator may tumuntunog na parang bumubula. parang blokblokblok(mabagal na pabilis) ang tunog. dahil ba un sa biglang release ko at di pa sya nka shift ng gear? kasi triny ko din na nka bwelo na tpos irelease ko ang accelerator ok naman. yung tunog lng ng turbo na sipol ang naririnig ko. medyo kaka kaba lng. not sure kung normal yung sound na yun. 2014 glsv automatic ang Monty ko. Thanks sa sasagot
    Same here, I also noticed this whenever I drive uphill... pag release ng accelerator meron same sound na prang blok blok blok pabilis... No idea what's going on. Anyone experienced this as well? Is this normal. I have 2015 GLS V, 5 mos old.
    #2360
    relax mga sir, ganyan talaga behavior nung vgt engine ng monty/strada.
    you will really notice it when going uphill, heavy accel then sudden release ng pedal. i call it tranformer sound, kasi parang yung sound effect ng autobots pag magttransform
2014 mitsubishi montero
