Page 158 of 307 FirstFirst ... 58108148154155156157158159160161162168208258 ... LastLast
Results 1,571 to 1,580 of 3070
    Feb 2011
    #1571
    pa-audition boss pagnatapos yung setup ;)
    #1572
    Anyone tried plastidip as a deadener?
    #1573
    i just grabbed a focal polyglass v2 27 subwoofer. ano po ba mono ampli ang maganda dito?
    Aug 2010
    #1574
    Quote Originally Posted by acgq View Post
    It won't work. Physics is against you for one. You need density in order to actually block a certain frequency wavelength. Bass wavelengths? Think 1/2 meters of concrete.
    #1575
    Quote Originally Posted by jhnkvn View Post
    im curious where he (acgq) got that idea.
    #1576
    From the plastidip can. It says there that it can be used to insulate and to deaden.
    Feb 2011
    #1577
    It will take a lot of plastidip cans to deaden a door. Because the goal in deadening is to increase the mass of the door/enclosure to make it rigid and free from unwanted resonance.
    Aug 2010
    #1578
    A better application is to simply try minimizing the area or partially sealing off "leaky" areas.
    The concept of sound-proofing is easy. Think of your car as a bubble that is insulating you from outside noise. The more holes there are, the more noise there is. On why the likes of German car manufacturers like Benz and BMW can make their car so quiet (compared to, let's say, a Kia Pride) is their attention to detail in trying to seal the car interior as much as possible from the outside. The likes of Lexus use double-paned glass for example. For Mercedes, this sometimes means using rubber grommets as much as possible to keep noise out as well as thickening some parts of the chassis.
    Feb 2011
    #1579
    Quote Originally Posted by kazer View Post
    nakaka adict kasi makadinig ng magandang tono na auto. lalo na nu na dinig ko yung pag kaka iba ng time aligned at hindi na sistema!
    after ko marinig sabi ko na lang sa sarili ko.. eto na nga... 1 time big time na! lets go for broke! este for gold pala...
    based on other hobby kasi mas magastos pag tinipid. na subok hehe
    btw.. settled with focal+ gladen combo.
    chief, may i ask, sa simplesound ba kayo nagpakabit? i saw a post with the exact set you planned to install on your system. if it is, padinig!
    #1580
    What is the advantage and disadvantage of using a line converter to connect a active sub to a stock HU that does not have a sub out?
audio set-up for beginners [continued]
