You want a generator house to hush that vociferous genset and at the same time safe, use metal tin roofing material riveted to g.i. metal wall studs. Make a double wall system with Fiberglas noise batts for noise and heat insulation. The volume of this enclosure approximately three times the dimension of the genset in cubic meters and provide vent system capable of around ten times air exchange per minute. Also provide for exhaust extension. You can make the panels collapsible for storage.
Posted through phlpost.gov.ph
