Page 53 of 91 FirstFirst ... 34349505152535455565763 ... LastLast
Results 521 to 530 of 902
    #521
    Remember the blackout in NYC? Can't run gensets, can't burn for heat(happened winter), how to get up and down to your unit floor and can't use candles and to include water pressure problems.;(
    Posted through phlpost.gov.ph
    Yup,- the problem of just too much regulation....
    “Familiarity breeds awe”
    23.8K:superhero:
    Jul 2011
    #522
    Quote Originally Posted by shibby75 View Post
    Kahit gusto mo bumili ng genset for your condo eh di mo din magagamit.
    condo's are required to provide lighting in common areas, water pump and atleast one elevator working during power interruptions, dyan napupunta ung part ng association dues. kaya kung ayaw nyo magbayad ng association dues sa lower floors na lang kayo bumili ng unit.
    Jun 2006
    #523
    I have a comercial groundfloor unit at regalia towers, tower genset only powers common areas and the elevator.
    Though pede daw ako maglagay ng sarili ko genset since nasa ibaba daw ako.
    I was just wondering kung pano ang buhay ng mga nasa highrise condo ng sm kung walang kuryente? Kandila? Emergency light? Di naman sila pde maglagay ng genset sa terrace.
    Jul 2014
    #524
    i'd certainly appreciate the cleaner exhaust from an LPG-fed genset, but in times of really dire emergencies, you may have trouble looking for LPG, whereas gasoline and diesel should be more available...heck, push comes to shove you can make ethanol/biodiesel; methane pwedeng DIY, but LPG?
    Hi, paano mo nasabi na mahihirapang humanap ng LPG?
    Hi guys, nagpapabili ako sa Dad ko sa US (California) ng LPG generator set, meron na rin bang mga LPG generator dito sa Pilipinas?
    Nagdadalawang isip kasi ako kung gas/diesel/LPG ang kukunin kong generator..
    any feedback guys?
    Kung kayo, ano ang pipiliin ninyo?
    Iniisip ko kasi ang LPG, may stock kami palagi kasi siyempre ginagamit namin sa pagluluto.
    Aug 2005
    #525
    Quote Originally Posted by Snowball0430 View Post
    any feedback guys?
    Meron ng lpg genset sa Pinas. Na feature ito sa GMA 24 Oras couple of days back nung nagpa-panick buying ng genset mga pinoy sa Raon.
    Aug 2005
    #526
    Eto napabili ako 3600w Denki. Gasoline fed open-type genset. Maingay sya considering it's an open type. Pero gagawan ko ng enclosure with sufficient vents and exterior pipe for the exhaust.Click image for larger version.
    Ok na kaya itong pangmatagalan?
    #527
    Meron isang ilaw Sa loob ng mga unit pag blackout sa mga condo.
    Posted via Tsikot Mobile App
    #528
    Quote Originally Posted by leinahtan View Post
    Nice thirty six hundred, bro....
    Ilang liters ang capacity ng tangke? Looks to me like 12liters+,- meaning you can run it overnight, without refiling the tank....
    23.8K:superhero:
    #529
    Ok na yan pang back up lang naman. Hinde mo naman papatakbuhin yan ng 24/7 saka na stuck lang yan pag walang matagal na power outage.
    Ngayon post mo na lang saan binili and price. Para May idea mga tsikoters price range ng never heard Sa branded
    Jul 2006
    #530
    Pretty much the same actually, on our part that is. The genset unit in our condo can power the common areas, elevators, water pumps, and for each unit a maximum of 3 CFL's, a fridge, and 2 electric fans. If you turn on a TV or aircon, a breaker switch will trip. You'd have to go down to maintenance and have it re-activiated again.
    This is a DMCI condo, I hope it stays the same in the future. Laking ginhawa in times of crisis.
Generator sets
