Results 111 to 120 of 1645
Tsikot Member Rank 4
- Feb 2004
- 1,704
August 14th, 2004 12:02 PM #111if you say na cost is not a consideration, then you will get a million different answers because cost is the biggest factor to consider when designing a system.
the advice that i can give is if cost is not really that big a deal, try to go with a 4 way setup. this is usually comprised of a pair of tweets, a pair of midranges, a pair of midbasses, and a single or pair of subwoofers. pwedeng full active or passive and active combined. a 4 way system with a good eq and crossover will be nice
andy
- Aug 2004
- 45
August 18th, 2004 10:30 PM #112I just bought a UP6 (di pa installed) I am looking for budget amp to power it and an installer that had previously installed speakers for RAV4 2004 model. Ayaw ko yung manghuhula kung paano tangalin ang door panels.
Tulong mga kaibigan. salamat
- Feb 2004
- 1,704
August 19th, 2004 10:02 AM #113tama ka dyan pare, go to an installer na maraming experience na kasi bad trip sung sigeng hila sa panels mo. pagkatapos ng install, dami ng squeaks and nakalawit na dahil sa sobrang pwersa.
andy
August 19th, 2004 10:50 AM #114
mach2audio sa pasig area. pwede rin sa mickey's autosound (same vicinity)
- Aug 2004
- 45
- Aug 2004
- 45
August 19th, 2004 11:44 PM #117
diba imomold pa ung bagong spealer with mdf pag magpapalit ka ng seps? nakita ko lang sa pics ni cardo. sa audiologic yata siya nagpakabit e
August 22nd, 2004 02:07 PM #118Step2. is to buy a good front speakers (2way seps preferrably 3way) not lower than 9k- 35k should at least 75-125w power handling depende sa level hanap mo. Recomended for a decent seps around 12k-17k(2way).
I have some experience in setting up my own Home Theater System (I ended up with 2 fronts and 1 center speaker with a receiver) kaya I know that one should spend kung gusto mo ng quality. And there are upgrades which aren't really, and will just make you upgrade again, leading to even higher cost.
Can you recommend:
(a) car audio shops na mabait ang owner who can take a look at my current set up and tell me what i should do first? i.e. tama ba na step 2, or puwedeng step 3 and 4 na lang, or dapat ba step 1 talaga;
(b) speakers in the 5k range? kung meron man? Hahahaha.
(c) websites that i should go to, so i can read up on what's a good set-up.
I'm after SQ btw.
August 22nd, 2004 02:26 PM #119
april ryan,
imo, mb quart, dls, jl ok sa SQ.
pero antay lang ako ng naka jbl GTO den audition ko, pag nagandahan ako sa tunog, un na lang bibilin ko. nasa 4-4.5k range lang siya...
try visiting www.kotseaudioclub.com
may mga tsikoteers din dun.
August 22nd, 2004 02:32 PM #120Originally posted by April_Ryan
I'm after SQ btw.
