Page 363 of 588 FirstFirst ... 263313353359360361362363364365366367373413463 ... LastLast
Results 3,621 to 3,630 of 5876
    Aug 2012
    #3621
    Quote Originally Posted by mr.president View Post
    Nice fc sir! Ask ko lang ilang degrees gamit mo sa aircon? Ako medyo agressive pa ang driving... Lagi kasi traffic ngayon, ayoko pang masingitan! Siguro after na lang ng christmas pagagandahin ko fc ko hehe!
    Nice FC nga po, nagulat nga rin ako e.hehe. Depende po kay kumander pero normally during AM nasa number 2 ung fan then nasa around 3/4 yung lever sa thermostat control. then sa PM number 1 nlng then the thermostat lever is adjusted 1 to 2 clicks to the left.
    Nov 2012
    #3622
    Quote Originally Posted by jinstan View Post
    For GLS owners: Does anyone here know kung paano palabasin sa touch screen monitor yung PSI and temperature ng tires? Lumalabas sakin kaso nakalagay blank yung PSI tapos yung temperature 0.. Ask ko lang kung pano ba isetup un using the touch screen. TIA!
    May additonal na upgrade ka pa na kailangan kunin - Tire Pressure Monitoring System (TPMS). Nung nag tanong ako sa SA na kausap ko, it's worth PHP 17K for all 4 tires.
    Dec 2012
    #3623
    Quote Originally Posted by egaieskie03 View Post
    sir habaan mo lang ang pasensya mo sa haba ng pila, meron pa nga dyan october pa hanggang ngayon wala pa, pero kung hindi ka mapili sa kulay na gusto mo e malamang iyan maunahan mo pa sila...good luck sir.
    oo nga po. I had mine reserved last October - GLS M/T. Till now wala pa din.
    Mar 2012
    #3624
    Quote Originally Posted by darkpanday View Post
    Is TPMS worth buying for 17K? I don't think so but well kung di problema pera pede ren.
    Aug 2012
    #3625
    Quote Originally Posted by *sludge* View Post
    sir maitanong ko lang po, dealer's discretion po ba ang EWD o standard po na kasali yun sa GLS na variant?
    standard freebies na po ngayon yan sa lahat ng dealer.
    Apr 2012
    #3626
    Maranong lang mga sir/mam, yung instrument guages, d rin ba lit yung inyo at start up? On lang kasi yung akin if on ko dim or headlights. Ok naman if on a bright day, pero tulad kanina n lakas ulan, medyo madilim, d ko makita. Is there a way n always lit yung instruments?
    Dec 2004
    #3627
    Ganun talaga, unless you have Optitron gauges or something similar. If it's raining hard, you should have your low beams on anyway.
    #3628
    Quote Originally Posted by nrthstr View Post
    Afaik ours are not optitron gauges sir..youll need to turn on the park lights to light it up ;)
    Jan 2008
    #3629
    Has anyone noted that there is no covering for Rear Plate number lighting, leaving a huge nasty opening exposing the electrical wires/bulbs and where dirt, dust, mud, and water can easily enter. What mods can you suggest for this.
    Apr 2012
    #3630
    Quote Originally Posted by Alpha_One View Post
    naman o..... anyways THANKS SIR!
2013 Mitsubishi Mirage
