Results 2,181 to 2,190 of 3710
- Oct 2012
- 5
October 24th, 2012 03:09 PM #2181mga master new member here! Ask sana ako ng tulong. Crosswind 2003 XUV ride ko. May alam na kayo na trusted mechanic sa cavite. Ipapacheck ko sana ball joint ko need na ata ng replacement. And sino may alam nung Isuzu Parts Shop daw sa Dasmarinas, cavite. Baka may makapagbigay ng directions. Thanks in advance!
October 27th, 2012 12:43 PM #2182
first time ko po kasi magdrive ng Crosswind matic...long drive pa manila to isabela...anu po ba dapat isa alang alang sa crosswind matic? anu ba itsura ng shifter?
sa manual lang kasi ako sanay...at dipako nakahawak ng crosswind
- Feb 2011
- 49
November 3rd, 2012 05:17 PM #2183Hi bros! The rear LH shock absorber of My 2003 Crosswind XUV is already due for replacement. Can you suggest a good replacement?
Based on what i've read most people say KYB brand is good enough. Can you suggest specific models, or the exact part number so it will be easier to ask around at parts shops.
Also, is it still possible to add about 1 to 2" lift to this model without doing extensive modifications? TIA!
- Mar 2010
- 143
November 6th, 2012 06:03 AM #2184share ko lang sa sluggishness issue with crosswind: recently meron akong ilang trips sa gas station para ipa drain yung separator dahil sa tubig at dumi nang fuel. decided na ipa-drain na din fuel tank. ayon, daming dumi/lkalawang na naipon sa tank at pipes.
after the cleaning, crosswind runs like the wind ;). ramdam ang difference sa responsivenes. may work for your, too.
- Mar 2010
- 143
November 6th, 2012 06:09 AM #2185Last edited by 14myXUV; November 6th, 2012 at 06:10 AM. Reason: wrong quote
November 6th, 2012 11:38 AM #2186
- Mar 2010
- 143
November 6th, 2012 11:47 PM #2187
- Feb 2011
- 49
November 7th, 2012 05:09 PM #2188Mgo brod, pwede pa bang i-lift or taasan ng 1 to 2 inches ang Crosswind XUV?
- Mar 2010
- 143
November 13th, 2012 10:52 AM #2189
- Mar 2010
- 143
November 13th, 2012 10:54 AM #2190
Tesla Philippines
