Page 35 of 42 FirstFirst ... 25313233343536373839 ... LastLast
Results 341 to 350 of 420
    Jul 2003
    #341
    I agree. It is totally impossible to evacuate the air from the ordinary rubber wheels so it is likewise impossible to have 100% nitrogen in it. Those in racing (i.e. F1 teams) may have the proper equipment to do that.
    #342
    Based on experience, I have a Strada GLS 2010 w/ TPMS. I have been a Nitro users for more than a year. I do quarterly checking and fill-up of nitro as needed. I always do it early morning 8am upon the shop opens. The tire is being filled up at 30psi. While it it being filled up and based on the Nitro machine that it is already 30psi, it will also show in my TPMS that it is also 30psi.
    While I'm using it for the next 3 month; in the early morning the gauge is lower than 30psi. While you are driving and when it is hot weather, the gauge stays at 30psi. Nitro helps the temperature of your tire at the right level and gauge always at 30psi. It is also a safety from tires to very heat that may explode.
    My tires are also more than 1 year but the spike depth is almost still near to a new tire. I never used the spare tire so I use a coin to compare.
    There is advantages to Nitrogen air in your tires.
    Oct 2011
    #343
    What is now the reading of your odometer since you use the nitrogen to inflate your car tyre?
    #344
    Odometer = 20050
    I'm scheduled for PMS.
    Jul 2003
    #345
    Quote Originally Posted by vhronx View Post
    Do you have similar measurements before using nitrogen? Because if none, you cannot actually compare if there is such improvement.
    Oct 2011
    #346
    I regularly check my tire pressure during every full tank of my gas. Normally, It is a 10km drive to the preferred gas station and whenever the pressure is check it reads 2.2bar just 0.1bar less of the standard tire pressure of 2.3bar. Never did I encounter during tire pressure check that It exceeded 2.3bar since the pressure will build-up when the wheel is hot.
    #347
    Mga sirs,
    Not sure if may thread na about this, ask ko lang sana pros and cons ng nitrogen filled tires.
    Thanks.
    Oct 2011
    #348
    Quote Originally Posted by benoy View Post
    Mga sirs,
    Thanks.
    very minimal lang ang pros afaik. ang cons, 50 per tire.
    Jan 2011
    #349
    Ang refill P50/5 tires at honda makati. Also, 3 months na since i last filled with nitrogen, 1psi pa lang nababawas.
    May 2010
    #350
    not worth it if you're only doing regular driving. It's only recommended for those High performance low profile tires with very abusive usage. Regular air is already 78% Nitrogen.
Nitrogen for Tires [Merged]
