Page 157 of 319 FirstFirst ... 57107147153154155156157158159160161167207257 ... LastLast
Results 1,561 to 1,570 of 3189
    #1561
    Quote Originally Posted by Fredericko View Post
    what's the logic when doing this?
    may be they are pertaining in resetting the ecu, like hard reset. parang nag format ng computer gaganda ang performance. apllicable sya sa mga programming ng ecu na may bug pa
    #1562
    Yup, that's resetting the ECU. That's sort of an instantaneous way of having the computer re-check its parameters. This is also done when you make some upgrades/mods. Instead of having the ECU 'learn' the new mods over time, you are putting it to sleep and slapping it awake right away.
    #1563
    is it the same with fiesta?
    Jul 2010
    #1564
    Quote Originally Posted by spymaker View Post
    sa ford fiesta thread. they disconnected the negative terminal ng battery for 5 minutes, press the brake during that time, then reconnect terminal. nag improve fc and gear change ng at nila. baka pwede yan sa inyo.
    Has anyone tried this already? Any update?
    I travelled from Sto. Tomas to Vigan. Had full tank (sagad up to apaw) and when I arrived in Vigan, still had 3 bars left. Hataw mode pala to.
    In the monitor I had 7.6L/100Km ~ 13.15Km/L.
    While city driving here in Vigan, my FC is at 11.3L/100Km ~ 8.85Km/L
    Is this consumption normal?
    My Odo now is 860+, so nearing my 1st PMS. I plan to have it done in Hyundai Laoag, any elantra owners who have experience in Laoag?
    Cause I plan to use semi-synthetic oil.
    Appreciate your feedback. Thanks.
    #1565
    Yes it's true. You can do that sa mga de-ECU. Sa Honda naman wala na kailangan gawin na iba just disconnect the negative pole.
    Sa Hyundai ganun din, disconnect the negative pole, 30 minutes is enough para sure na naka-reset ang ECU. Or pagawa niyo via GDS, better yun.
    #1566
    Feb 2005
    #1567
    was anyone able to make the inner tail lights work when the headlamps are on?
    #1568
    Quote Originally Posted by t43m4n View Post
    i just install it last nyt and its look good when lighted, may abang na sa terminal ng reverse light., bumili lang ako ng peanut bulb socket sa banawe then, drill the hole , may pattern naman sa tail garnish
    Feb 2005
    #1569
    Ow di ako magaling mag DIY. Just drill the hole and plug in the peanut bulb? how about the wires?
    #1570
    Quote Originally Posted by Jackdripah View Post
    Sounds reasonable, i heard many people are changing to fully synthetic after its properly broken-in. around 10T km...
    sounds reasonable, accdg to US Govt. EPA measurements, the car can do 40mpg (hiway) so that's around 17km/li... pero since ang hiway naman sa atin ay madami dami din ang slowdown and re-acceleration. kaya siguro mas mababa. pero not bad na 'yan...
    tungkol naman sa oil, normally mga 10T km. sila nag papalit to semi-or fully synthetic oil.
2011 Hyundai Elantra [MERGED]
