Results 1 to 10 of 258
    Jan 2009
    You can't change fan speed or oscillation with a smart plug. Wanted to add my Sharp stand fan into my smart home environment but on/off lang kaya.
    I'm considering this Toshiba fan with digital controls which can be controlled by my smart RF blaster.
    Toshiba F-LSA2(W)PH Remote Digital Fan 16inch
    That is true. We keep the fan at the lowest speed and the oscillation turned on in the bedroom and use a smartplug to control its power. I use a routine so it works in conjunction with the A/C.
    There's also a fan in the kitchen but this time, the oscillation is turned off.
    99% of the time, we're fine with this configuration so cheap fans + smartplugs work.
    Yung Sharp nga matibay, parang 4-5 years na yung isang stand fan namin. Yung desk fan na niregalo ko sa Ate ko eh mga ganun na din katagal. La pa naman issue.
    Naiinis lang ako dun sa mga bolt type lock. Hassle pag naglilinis. Mas convenient yung quick release type levers na 3 at isang kumakapit sa taas. Hehe
    Para daw feeling technician pag nagkakalas. Ok din yung lock ring type.
    Nice yan ah. What price range niyan?
    1st pic is 2.6k to 3.xxk bro. 2nd pic mahal, 5.xk, ka presyo na ng mga inverter fan.
    Hehe, need pa talaga Phillips screwdriver eh.
    Pero maganda naman Asahi, Japan ang motor niyan afaik lalo na nung unang labas yun pinagmamalaki nila.
    Tsaka maganda nga design especially yung brown and black sa 1st pic.
    Kung yung sa 2nd pic, kapag nasira motor, dapat palitan lang yun kasi pang-matagalan yung body at fan frame, sayang na itapon lang hehe.
    I've had one of this since 2013. It still puts out massive blasts of air that cool the room down fast. Don't have any loose paper lying around.
    I haven't had the need to use any other setting except the Lowest Speed.
    Jun 2015
    This looks interesting. 30W max lang.
    Panasonic DC Inverter Stand Electric Fan F-49SS | Lazada PH
    What I like about Panasonic electric fans is yung oscillation nya smooth at consistent ang speed.
    Compared sa mga Hanabishi, Asahi etc. na nagiging jerky sa katagalan at may slight pause pagdating sa dulo bago siya bumalik sa kabilang direksyon.
    Downside nga lang pag nabasag yung plastic gear na nagpapa-oscillate, mahirap makahanap ng pamalit.
    I was comparing the wattages too vs the normal non-dc 3-4speed fans. This will have lower air pressure/volume.
    The normal 55w fans 1st speed is probably around 15-20w which is low naman.
    Mahal nga. Saw this in Ansons kanina. Didn't ask how much net after discount.
    Ok din sana if DC motor na ginamit nila diyan sa retro fanClick image for larger version.
What's the most durable electric fan?/Electric Fans Talk
