Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
    Jan 2009
    #31
    Attachment 18847Attachment 18847
    This is the hard disk inside the casing.
    Looks like the USB3 interface is actually part of the hard disk PCB. No way to retrofit that to a SATA or even an IDE interface.
    Found the following video. It appears that newer WD Passport drives have this USB-integrated module in the hard disk controller.
    Apr 2010
    #32
    Bakit hindi madetect yung WD My Passport external hard drive na kakabili ko lang kahapon when plugged sa TV?
    Sent from my ASUS_Z011D using Tapatalk
    Jan 2018
    #33
    Quote Originally Posted by myas110 View Post
    Try to change the partition method to MBR
    Apr 2010
    #34
    Quote Originally Posted by SpinCycle View Post
    What is MBR? and how to do it? Kasi I'm planning to change it from NTFS to FAT32 (but the option FAT32 is not available sa windows... need ko pa ng third party app to do it)
    Jun 2015
    #35
    Possible na incompatible disk controller. I have a USB SATA hdd enclosure na nadedetect sa pc but not by our TV. 80GB lang ang laman nun and it works flawlessly sa Windows and Linux. Try mo sa ibang TV yung hdd mo.
    Sent from my ASUS_T00J using Tapatalk
    Apr 2014
    #36
    Parang common issue ata ang di pag detect ng WD drive at samsung tv
    WD Elements 1TB HD Compatibility Issue with Samsung LED TV - [Solved] - Storage
    Apr 2010
    #37
    Quote Originally Posted by chronicle View Post
    Okay.. so, common issue sa WD External hard drives yung compatibility sa mga Samsung TVs. Or baka dahil outdated yung firmware ng TV namin kaya hindi compatible? Or compatible lang siya sa Smart TV?
    AFAIK, yung ibang external hard drive (I guess it's a Seagate) ok naman sila, detected naman.
    Will try it onceI go back to Manila. Thanks
    #38
    Yes pwede outdated yung firmware ng TV. Might as well update that to eliminate as a cause.
    Sent from my SM-G965F using Tapatalk
    Apr 2010
    #39
    ^ sa bagay... I opted not to format ulit yung external hard drive.. instead I bought a 32gb 2-in-1 USB (OTG) para dun ko na lang i-copy yung movies and at the same time, I can use it sa mobile phone ko.
WD My Passport external hdisk can't be detected
