Results 51 to 60 of 211
- Aug 2015
- 220
November 22nd, 2015 05:10 PM #51I plan to install next year a solar water heater it seem reliable for the initial cost of 25k peso, compare sa e-water heater na masyadong malakas sa electric bill
- 53,883
November 22nd, 2015 07:36 PM #52it's easy to attach.
if you are a handyman of sorts, you can do it yourself.
or you can hire a good tubero or all-around handyman.
a problem might arise, if your wall-mounted heater has a limited gallon per minute capacity. it might not be able to supply enough heated-enough water, for you to fully enjoy your large head (errr.. showerhead, sir).
some product shower heads may indicate in the package the minimum required gallon per minute requirement...
also, is your water source powerful enough to supply your system's needs?
the wider the showerhead (more holes), the stronger the needed pressure..
good luck.
November 22nd, 2015 09:52 PM #53
good call thats what i did. but you may need a backup water heater in case of rainy days.
got an aeg multi point as backup. used it one in awhile when 2 days walang araw or really dark clouds for 2 days. maybe used it less than 10x this year of 12 months
- Aug 2015
- 220
November 22nd, 2015 10:54 PM #54good call thats what i did. but you may need a backup water heater in case of rainy days.
got an aeg multi point as backup. used it one in awhile when 2 days walang araw or really dark clouds for 2 days. maybe used it less than 10x this year of 12 months[/QUOTE]
Good to know, what can you say about performance, does it really satisfy your needed heating temperature or lets say how many people had to use the shower bago maubos ang init and by the way ilan liters ba capacity ng solar water heater mo?
November 22nd, 2015 11:33 PM #55
Thanks for the tip about the gallon per minute capacity! I'll check that out with the existing heater.
I was concerned about the water pressure too, thanks for pointing out the more holes + stronger pressure needed!
Really appreciate it!
November 22nd, 2015 11:36 PM #56
3 lang kami morning and evening showers. Never ran out of hot water during normal days. I forgot na how many liters but it is a single tank setup. 4 or 5 years na namin ginagamit. Once a year i have the o rings coated with silicone grease.
November 23rd, 2015 03:21 AM #57
- Apr 2013
- 68
December 27th, 2015 06:19 PM #58Ask ko lang po kung may nakatry na po sa inyo nung alpha na brand? If yes, kamusta naman po? Thanks!
- Dec 2012
- 397
December 27th, 2015 06:26 PM #59
- Apr 2013
- 68
December 27th, 2015 09:02 PM #60
Tesla Philippines
