Results 1 to 9 of 9
September 16th, 2004 07:37 PM #1
guys,
i'm tyring to setup our INHOUSE mail server here in the office! I have some problems configuring it though... i set it up as instructed in the procedural manual - problem is i CAN SEND, but I CAN NOT RECIEVE emails...
all MX / DNS & Ahost records are working perfectly fine (via the DNS Querry Tool that comes with the program). The Mail Server is "Pingable" from the internet, no problems are found if u run the Dns Checker as well.
From the ERROR LOG, there appears to be no error at all!
Did i missed anything? H.E.L.P :confused:
Thanks in advance...
September 16th, 2004 07:42 PM #2
could it be due to routing?
here's our set up:
DSL to SWITCH: connected by a CROSS cable
SWITCH to ROUTER : connected by a CROSS cable
ROUTER to MAIL SERVER: connected by a straight UTP cable.
SWITCH to LAN - all distributed by a straight cable
thanks again!
September 16th, 2004 09:38 PM #3
Try mong mag telnet Mailserver 25, outside firewall or on the Internet side. This is to see if SMTP Port 25 is open on your mail server on the Internet side. Otherwise your MAilserver will not received emails via SMTP from Internet sender.
September 17th, 2004 09:50 AM #4
thanks doublea - but i already did that, both ports 25 & 110 are open and responds accordingly on telnet.
any more possible causes? are you familiar with MERAK, meron ba syang ACCL - acess client control?
thanks again!
September 17th, 2004 12:36 PM #7
check your dns configuration.
dapat meron kang MX record entry that points to your mail server. in addition to the 'A' record.
September 17th, 2004 01:37 PM #8
Go to www.dnsreport.com and enter the name of your zone file to check for configuration errors.
- Jan 2004
- 218
September 17th, 2004 06:46 PM #9I-tsek mo yung mailq mo baka na-stuck yung incoming mail.
Did you send a test mail to yourself within your domain?
Are you using IMAP or POP?
