Results 31 to 40 of 42
November 16th, 2006 11:07 PM #31
sana naman hindi sira ang antenna
try ko muna ulit sa ibang wifi spots.
November 16th, 2006 11:33 PM #32
built in ba yung wireless mo? try mo adjust yung power management.
Start/Control Panel/System/Hardware/Device Manager/Network Adapters/wireless connection/right click then click properties. tapos select mo yung Power Management then uncheck mo yung default tapos move mo yung cursor sa highest value.
try to connect to the internet even your signal strength is low. If ok naman yung connection mo, dont be bothered by the low signal. sakin kasi ganun eh.
November 16th, 2006 11:42 PM #33
November 16th, 2006 11:44 PM #34
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 17th, 2006 12:04 PM #35If Centrino then you have a Pentium M, an Intel chipset and Intel wireless.
Don't worry about it as long as you can connect to the wireless network at a respectable speed. I have experienced the same problem. Sometimes, my 2 laptops are only a foot apart and they have different signal strength. Other time its the same.
November 17th, 2006 01:05 PM #36
November 17th, 2006 11:42 PM #37
November 17th, 2006 11:45 PM #38
test ko nalang next week pag dating nung inorder ko na linksys wifi router. hiram din ako ng notebook sa friend ko.
November 20th, 2006 01:04 PM #39
mukhang wala naman problema sa wifi ko. just installed my new linksys wireless router and full bar kapag within the room, and nakaka 1-2bars at the other end of the house with 3-4 walls in between.
November 20th, 2006 02:11 PM #40
