Results 1 to 10 of 277
- Feb 2008
- 898
August 21st, 2013 10:04 PM #1Been scouting for a brand new ref...
What should I consider....
1. Frost vs. Non-frost....
2. Single or Two Door....
3. Cubic Size.....
4. Brands......
5. Efficiency Rating for Power consumption....
Budget is around 20k....
August 21st, 2013 10:18 PM #2
- Jul 2011
- 1,711
August 21st, 2013 10:44 PM #3Inverter po para tipid sa electricity bill, kung mapapansin mo ung mga inverter ang mataas ang efficiency rating
- Feb 2008
- 898
August 22nd, 2013 07:15 AM #4Digital Inverter Compressor - This is what Samsung posts in their site:
"Unlike conventional compressors, which have just two patterns of start and stop, Samsung’s Digital Inverter Compressor makes 5 different moving cycle based on humidity levels and usage patterns. This helps maintain a more consistent temperature, reduces wear and tear on the compressor for greater durability, and keeps noise to a minimum. You’ll also enjoy the peace of mind that comes with lower electric bills and a 10-year warranty."
Sirs, is this the Inverter you are referring to?
- Jul 2011
- 1,711
August 22nd, 2013 08:26 AM #5madaming brand po meron ng inverter, select po ung model na best suited to your needs.
wag ka po magpapadala sa laki ng discount sa mga old type na ref (ung compressor)
ung iba nga hindi na nilalagyan ng energy rating kasi ang laki ng difference compared sa inverter.
August 22nd, 2013 09:58 AM #6
1. No frost
2. Two door (saves energy as you only open the compartment you need to access)
3. Cubic size? Depends on your needs, what you intend to put inside, how often do you stock up on meats, etc.
4. I'd consider Panasonic, Condura/Kelvinator, GE, and perhaps, Samsung. First choice is Panasonic.
5. Go for the one with higher energy efficiency rating; if you can afford it, put out extra PPP for the Inverter type units as these are the trend and are said to have lower electricity consumption.
August 22nd, 2013 10:18 AM #7
nasa 100w yata consumption ng 12cu.feet na samsung inverter. was supposed to get 1 few weeks ago.
August 22nd, 2013 10:33 AM #9
Tesla Philippines
