Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    finally got one from an electronic store ... smallest size lang available, dumudulas ... but i managed to unscrew and fixed the darn adapter ... broken cable lang ang problema but the break was just inside the rubber grommet ... if i simply cut the grommet and solder the broken conductor, it won't be as reliable as cutting the cable, resolder the ends to the pcb inside, and grommet goes to the bin
    thanks
    Aug 2005
    Designed ang screw na iyan na di nabubuksan kaya ganyan ang itsura.
    Di ba sa Singapore ang plug iyan?
    british standard ... so yes it is designed for all places that use the standard like singapore, a former british colony
    and yes it does look like it is designed for clockwise (for tightening) only but the correct screwdriver can still unscrew it with due care so as not to wear out the head as it tends to slip
Saan makabili ng screwdriver ...
