Results 11 to 17 of 17
February 5th, 2015 04:54 PM #11
February 5th, 2015 05:23 PM #12
February 6th, 2015 09:53 AM #13
The blower is being used to transfer air from one chamber to another.
Also, I don't know how to call this, but at startup, the motor operates at a lower rpm, and then switches to its normal operating rpm (around 1760rpm) after a while.
So far, it's been operating normally without any noticeable difference in performance.
So far, it's been operating normally without any noticeable difference in performance.Signature
- Nov 2002
- 1,326
February 6th, 2015 10:07 AM #14on lower rating motor:
kung transfer air lang fr 1 chamber to the next.. walang temperature na mine maintain (kaya binubugahan o hinihigop ng air) I suppose ok lang...
on savings ng electricity - in the same concept / application of inverter air conditioning.. bulk of the savings you get from is sa frequency ng pag on/off ng motor ng blower mo... if it is constantly on.. di gaano kalaki ang konsumo ng kuryente... kung madalas on/off ang blower mo.. I suggest pakabitan mo din ng inverter... mahal man ito vs sa ordinary contactor.. savings in electricity you get will more than pay for the cost of inverter...
yung lower rpm ng motor sa startup.. duda ako yan ang manifestation na lakas ng konsumo.. baka d naka balance ng husto ang blades ng blower? ilang inches ba ang blower? baka ito reason kung bakit 25hp sinalpak nya. para dna pwersa sa startup..
February 6th, 2015 10:56 AM #15
The lower startup rpm is part of the startup process. Not because of the lower rated motor. Kahit nung naka 25hp motor talagang ganyan ang operation.
The lower startup rpm is part of the startup process. Not because of the lower rated motor. Kahit nung naka 25hp motor talagang ganyan ang operation.Signature
- Jan 2015
- 468
February 6th, 2015 01:22 PM #16Motor rating sometimes is based on the designers assumptions.
As long as the old motor (25hp) and the new motor (15hp) has the same rpm, it should not be a problem considering all pulleys are the same.
The only item you need to check is the motor running ampere if it is overloaded or more than 80% of its full load ampere. If not, its fine.
Just an FYI, on my previous work we have 40TR AHU that have a 40hp motor, and sooner replaced the motor with 20hp. Cheaper in electricity and re-designed R.J. Calpo.
- Jan 2015
- 468
February 6th, 2015 01:24 PM #17
