Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    wala akong alam sa PC, ito problema pag on ko na tapos nagboot na siya lumalabas yun CMOS? ang nakasulat is date and time not set, everytime i on ko lumalabas ito tapos kailang ko iset yun date and time tapos pag mag meron prompt na save and exit changes diba dapat ok na yun, kaso pag tapos na ako gumamit tapos gagamit ulit ako pag on ko na ulit lumalabs ulit yun, everything is normal except yun CMOS na yan for time? ano dapat gawin? pls step by step yun parang 5 yr old na bata ang tinuturan kung anong gagawin TIA
    Jan 2003
    palitan mo na yung back-up battery sa motherboard.
    Sep 2006
    yup sir shadow patay na ata yung cmos battery mo. yun yung nasstostore ng cmos setting mo eh. parang battery lang yung ng relos sa mobo mo. ok lang namn yang ganyan if you could live na ilalagay mo yung date at wala kang programs na nagdedepend sa time. pero kung madalas ka sa net tapos may softwares ka na may expiration or validity period, baka magkaproblem ka kung hindi maaayos yan. palitan mo na lang yung batt tapos set time, dapat ok na yan.
    ok thanks, so hardware pala ang problem, akala ko kasi meron ako nagalaw sa settings...
    how much yun batt na ganyan? saka ano brand na maganda or meron din bang mas magandang rating or something?
    Apr 2005
    Quote Originally Posted by impulzz View Post
    Sir impulzz is correct. you have to change the backup battery sa motherboard. it is almost the same size of one peso coin. check the specs and buy it at any watch repair shop or Ace hardware. nakaclip lang ito.
    Apr 2006
    change the cmos battery. it looks like the battery sa relo. around P50 to P200 pesos lang yan. it stores the bios information when your pc is turned off.
    Basta ganyan ang lumalabas dead na ang CMOS battery. Palitan mo na lang.
    Jul 2006
    buy a 2032 flat battery... Open your motherboard case, locate the battery on your board... replace...
    Actual price: 50 petot in 30 mins...
    Pag pinagawa mo sa Shop
    Actual Price: 550 petot in 5 mins...
    so basta isa lang ang batt dun sa mother board, hinde na ba kailangan soldering? hinang ba tawag doon?
problem with my PC, pls help
