Results 1 to 7 of 7
boybi Problem with File Exporer April 1st, 2008, 09:45 AM
mazdamazda Re: Problem with File Exporer April 1st, 2008, 10:00 AM
chilli Re: Problem with File Exporer April 1st, 2008, 12:11 PM
ghosthunter Re: Problem with File Exporer April 1st, 2008, 01:14 PM
boybi Re: Problem with File Exporer April 1st, 2008, 01:21 PM
    There are times when I'm renaming or deleting a file or folder in Explorer, I'll get an error message saying that the file/folder is being used by another person or program, hence I cannot rename/delete the file/folder. But after a few seconds, I can rename/delete it without the error message.
    Is this caused by a virus or spyware/malware? Or is someone sneaking into my computer via the internet? I'm using a router and I have firewall installed.
    Hmmm... parang virus nga yan boybi.
    Jan 2008
    Not necessarily someone's sneaking in your computer. Usually this problem can be fixed by rebooting. This happens to me all the time. But you can also fix this without rebooting.
    Make sure that you are using Admin acct. Then you can stop this in the Task Manager (you can use Help of Task Manager). Then run disk check and if you don't have it down load registry repair software. Run both.
    Or use this one
    http://ccollomb.free.fr/unlocker/
    Hope this helps.
    Sometimes the system is getting the properties of the file or folder during your delete operation. Wait a minute and then try again. If it still gives you trouble, restart Windows and try again.
    Thanks chilli! Ayos yang unlocker.
    Jan 2008
    No worries. Been using that kasi i always encounter this problem. Tamad ako mag reboot eh
