Results 151 to 158 of 158
February 11th, 2008 03:56 PM #151
Google results for Plasma vs LCD doesn't really give definite answer. What i learned though is for 40" above, it would be Plasma. 37" and below, LCD is the way to go. For Movies, Sports - Plasma. For games, picture slideshow - LCD.
If i have 100K+ to burn on TVs alone i'd get these two:
Panasonic 42" Plasma TV TH42PV70 - P55K
Sony 32V300 - P54K (with home theater + wireless headphone) OR
Hitachi L32A01 - P38K
Plasma for my home theater, LCD for everything else
Sarap mangarap.
February 11th, 2008 06:01 PM #152
1080p hdtvs (FULL/ULTRA HD) costs almost twice as much as the common 780p/1080i right now
. kelan kaya bababa presyo nito?
Tsikot Member Rank 4
- Jan 2007
- 2,326
February 13th, 2008 12:38 AM #153I just got a 42" Hitachi plasma for less than 70k. I hope it's durable -- too bad it's for the company and not for me. I STILL don't want to spend that much mega bucks for a TV.
February 13th, 2008 02:15 PM #154
1080p, 780p, 1080i...would it really matter to you? Here's a very informative post from the playstation boards:
http://boardsus.playstation.com/play...=938503&page=1
Okay, it's time for another of my informative posts... If you've seen any of my other posts:
Understanding HDMI cables and why cheap ones work perfectly
Ground loop causing horizontal bars and/or buzzing
You know that I'm a broadcast engineer and live and breath this stuff every day. As part of my trade I have to keep up with TV's, broadcast signals, HD signals, etc. So I've been able to bring some of my knowledge to these boards and help others get informed on various topics.
With that in mind, since I've been seeing a ton of these types of questions asked lately, I thought I should create a post dedicated to giving some answers... So with that said, let's proceed...
"Should I run 720p or 1080i", "What's the difference between 1080i and 1080p", "Should I get 1080p or just 720p", "Will I notice a difference between X and Y", etc...
These are all questions I see asked all the time... The problem is... There is no one fixed answer. It depends on a lot of various factors, and the only way to really be able to answer this question is by understanding what the differences are... So here we go, let's get into the fun stuff...
Section A: Resolution
The first thing you have to understand is the resolution of your TV set. A recent HD set (microdisplay LCD, DLP, LCoS, or Plasma, or directview LCD) can have one of three resolutions.. 480 lines of resolution, 720 lines of resolution, or 1080 lines of resolution.
Now your first thought may be that "bigger is better"... The more resolution, the more detail, and hence, the better the picture. The problem is, that doesn't really apply. Here's why... The smaller your TV set, the smaller a given number of pixels will become... Once they get below a certain size, then it just doesn't make any difference if they get any smaller.
For example... Take a look at this... Let's say you have a massive 350" monitor that your viewing this message on... If we were to walk up to the screen and take a look at . <-- that's a period... We might see that it looked like this for whatever resolution you were running at:
See... A nice rounded period... Looks good, decent detail.... If we count up the pixels that it's made out of, we see it's made of 20 pixels...
Now let's say on the SAME 350" monitor, we drop down to a resolution that's half of what we were running before... Now if we go up close and look at the SAME period, we might see it looks like this....
Now it's not so nice and rounded, doesn't have as much detail, and in general just doesn't look as nice... This seems to support the "more resolution is better" theory... But here's the problem... We're looking at this UP CLOSE on a 350" display...
Now let's say your using a nice 19" monitor right now.... Take a look at this . <--- another period...
That period (depending on your resolution) might be made of say 4 pixels... Would it matter if you switched resolutions to 38928282x3892202??? Nope, even if that period was made up of 100 pixels instead of 4, because it's so small to begin with, it's going to look EXACTLY the same... The extra detail might be lost, but it's lost on a level your eyes can't see to begin with...
With that in mind, that's why a set with a maximum 720 lines may be just as good as a set with a maximum of 1080 lines... Depending on it's size... Once the pixels get so small, it doesn't matter if the detail is lost anyway... Of course this varies based on your eyesight, and also the size of the screen vs your viewing distance. In fact, here's a really nice chart that demonstrates how resolution relates to viewing distance and tv size...
So as you can see, let's say your buying a 40" TV... The ONLY way you'll be able to tell the difference between a 1080 lines of resolution and 720 lines of resolution is if your sitting 5ft away or closer... If your buying a 50" TV, it's about 7 ft... 60" makes it about 7.5 to 8ft... So the honest truth is, in most peoples living rooms at normal viewing distances, you won't see the advantage of 1080 lines of resolution anyway.
Now, before we move on to interlaced vs. progressive, there's one other thing I'd like to point out that most people don't realize...
I've heard a lot of people say "I have XXX tv, and when I switch to 1080i I see a big difference in picture quality vs. 720p" Almost 98% of the time you see this statement, it's flat out false... In fact, it's IMPOSSIBLE in most cases for them to see a difference... Here's why...
If you have a microdisplay TV (i.e. DLP, LCD, or LCoS), or MOST plasma's and directview LCD's, and it DOESN'T say that it's 1080p, guess what? The MAXIMUM resolution it will support is 720p... Now I can here some people now, "That's bullcrap! I set my stuff for 1080i all the time"... Sure you do... That's because it WILL accept a 1080i signal, but the problem is, the display chip inside it only has 720 lines of resolution, so that 1080i signal just get's downscaled to 720p before it's displayed anyway... So switching between 1080i and 720p will have NO effect on the picture quality, other then 1080i will introduce motion artifacting which will make it look worse! (we'll get to this in a moment)...
If you have a CRT set, your LUCKY if it get's 720 lines of resolution.. Most don't support even that. They accept the signals, but can't really display anywhere near the level of detail that a microdisplay or plasma or directview lcd can... Now again, there's probably someone barking that their CRT set looks better then xxx set... This is BECAUSE of the loss of detail...
This is the same reason photographers have been shooting portraits with "soft focus" lens and/or filters for years... Because the DETAIL of a persons face RARELY ever looks "good"... The soft focus "blurs" the image, which looks MUCH more pleasing... The same applies with CRT sets... The "blur" or "softening" effect they have on signals often makes BAD signals look MUCH better... However, get a GOOD HD signal and it won't even come close to comparing....
So in other words, just because your set will ACCEPT a 1080i input, doesn't mean it DISPLAYS 1080 lines of resolution, almost CERTAINLY it displays 720 lines...
Now... The next half of what you need to understand is interlaced vs. progressive... So let's move on...
February 13th, 2008 02:22 PM #155
continuation...
Section B: Interlaced vs. Progressive
Okay, to start this lesson off you have to understand frame rate... So let's start off with the magic number.... 60... You may or may not know that our electricity runs at 60hz... (i.e. the frequency of the sine wave of the AC current is 60hz, or 60 cycles per second)... (I'm speaking of US and other NTSC countries here)
Because of this, your TV will update it's picture on the screen exactly 60 times per second... That's it, plain and simple... It will ALWAYS be displaying 60 "images" on the screen in any given second...
Now let's say we have a video signal that's nothing but 4 lines of lines... If it's a PROGRESSIVE signal, it would be drawn like this...
1:----------
2:----------
3:----------
4:----------
each line 1 thru 4 drawn in that order, 1 thru 4... one right after the other... 60 times per second.... Each "full picture" is called a "frame"
If however that signal was an INTERLACED signal, it would be drawn like this....
1:---------
3:---------
followed by
2:---------
4:---------
each of those is 1/60th of a second... so 1 and 3 get drawn, then 2 and 4, that's 1/30th of a second... then 1 and 3 are repeated, then 2 and 4, etc... In other words, it's drawing EVERY OTHER LINE in each "picture" rather then ALL lines... Each "half picture" is called a field... 2 fields "add" together to make a "frame"...
Okay, so now that you understand that, let's describe some of the ATSC signals that are defined... There's actually a bunch (18 in total) but we'll just talk about a few...
720p: This is 720 lines of resolution, with a frame rate of 60 frames per second... This means ALL 720 lines are drawn in order every 1/60th of a second...
1080i: This is 1080 lines of resolution, with a FIELD rate of 60 fields per second... It takes 2 fields to make a frame, so therefore it's 30 frames per second, i.e. every FIELD takes 1/60th of a second and is only comprised of HALF the lines... 2 fields are drawn every 1/30th of a second, and "added" together by our eyes to get a single frame.
1080p: is of course 1080 lines of resolution, with a frame rate of 60 frames per second... All 1080 lines drawn in order every 1/60th of a second...
So.. .with this information in mind... You might be thinking... well... 1/60th of a second is way too fast for our eyes to see.... So even though each FIELD in an interlaced signal is only half the information, they still get "added" together by my eyes, so there's no difference between interlaced and progressive...
And as long as you were viewing STATIC images (i.e. non-moving pictures) you'd be ABSOLUTELY correct.... The problem is... We don't typically view non-moving images on a TV... There usually is movement involved, and it's this movement that causes the problem...
That problem is called "motion artifacting"... See, here's the thing... Let's say we have a box moving across the screen... Let's just look at a 1/30th second time slice...
If we have a progressive display, then in 1/30th of a second we'll get two frames... Those frames will look like this....(again simplified to 4 lines of resolution)
Frame1:
1:+----------+
2:+----------+
3:+----------+
4:+----------+
Frame2:
1: +----------+
2: +----------+
3: +----------+
4: +----------+
As you can see, the box looks great, and the motion is evident... As we start rolling through these frames we'll see it smoothly move across the screen....
Now let's take a look at an interlaced display... Iin 1/30th of a second (the same time slice) we now have two FIELDS instead of FRAMES... But remember, the box has moved the SAME amount in that 1/30th of a second as above... This means we'll see this...
Field1:
1:+----------+
3:+----------+
Field2:
2: +----------+
4: +----------+
You see, the box moves the same because that's based on the speed it was traveling.. However, because it now takes two fields to make a frame, and because each field is only half the information, our eyes put those two fields back together... That means that for our 1/30th of a second "frame" we see this...
1:+----------+
2: +----------+
3:+----------+
4: +----------+
See the problem here... Now if we expanded that out to 2 frames we'd see this...
1: +----------+
2: +----------+
3: +----------+
4: +----------+
So that's what you see moving across the screen instead of the nice "square" you see with progressive... The edges get "torn" between frames because of the "motion artifacting"...
This is why, especially for video games, interlaced is kinda bad...
Section C: Summary
So with this information in mind, it's easy to see why the choice can be so dependant on MANY variables...
What resolution is your tv REALLY capable of displaying?
If it's 720 lines of resolution native, then it's SILLY to feed it 1080i, since you'll STILL get 720 lines of resolution, it's just going to have motion artifacting... If your TV displays 1080 lines of resolution, but will only ACCEPT a 1080i signal, then you'll have to make a decision... Based on the chart above, will you see the difference between 720 and 1080 lines? If you WILL see a difference, then which is more important to you, a little added detail or the motion artifacting? If your TV displays and accepts 1080p, then it's a no-brainer.. 1080p all the way...
If you haven't bought a TV set yet, then should you buy 720p or 1080p? Again, it depends on the size of the screen you intend to buy and what your viewing distance will be (again, see chart above)...
If you DO decide to go for 1080p, MAKE ABSOLUTE SURE the tv actually ACCEPTS 1080p signals... a LOT of TV's were sold as 1080p tv's that would ONLY accept 1080i signals... They just upscale 1080i to 1080p which sounds great until you realize as above, you'll get the motion artifacting in it, so what's the point anyway?
- Mar 2007
- 98
turbo
- Nov 2002
- 503
March 15th, 2008 06:55 AM #157I just got a 58 inch Panasonic Viera for my Home theater. The 58 Viera now renders my projector obsolete!
March 21st, 2008 11:05 AM #158
LCD and Plasma Price Watch
http://pinoydvd.com/board/index.php?topic=65921.810
Tesla Philippines
